Mathematical Modeling of an Elevator System
The discussion focuses on modeling the energy consumption and power of an elevator system, emphasizing the need to input various parameters like cab weight, motor types, and gearing systems to calculate peak and RMS power. The user is utilizing Mathcad and Maple to analyze the elevator's speed profile, including jerk, acceleration, and distance traveled over time. To analyze the system's energy, it is suggested to consider the change in potential energy from elevation changes and the kinetic energy required to accelerate and decelerate the cab. Additionally, defining a cycle history is recommended to assess the energy changes throughout the elevator's operation. The goal is to create a comprehensive model that accurately reflects the energy dynamics of the elevator system.
hornet09
Hi, I'm a physics major working an internship for an engineering company at present. I have been trying to model the energy consumption and/or power for an elevator system. The goal is to be able to input different variables (cab weight, capacity, counterweight percentages, motor types, gearing systems, etc) and be able to get a peak power and RMS power. I have been using Mathcad and Maple to analyze the speed profile of the elevator, and have created a program that allows me to view the jerk, acceleration, velocity, and distance traveled of the elevator as a function of time. My question is: how do I analyze the energy of the system.
Known values are:
Cab weight, capacity, counterweight percentage, rope weights, hoistway efficiency, motor efficiency, gearing efficiency, elevator profile speeds (jerks given, acceleration given, holding velocity given), pulley radius, building height.
We can assume that the elevator gets fully loaded on the ground floor, travels to the top floor, everyone exits, and travels empty back to the ground floor.
Figure the change in potential energy due to the change in elevation and the change in kinetic energy to get the cab from rest to its travel velocity and back to rest. You will probably need to define a cycle history, which can be analyzed to determine the changes in energy required to move the elevator.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
