How to calculate how long a battery will last
  • Thread starter Thread starter bobjenkins777
    Battery
To calculate how long a battery will last, one must consider both the battery's amp-hour (Ah) rating and the device's power requirements. A 12-volt battery rated at 250Ah can provide significantly less capacity under high loads, as efficiency drops and power inverters consume additional energy. For example, using a 10,000 BTU device requires converting voltage, which increases the current drawn from the battery. It's crucial to understand the difference between energy (watt-hours) and power (watts), as well as the limitations of lead-acid batteries, which should not be discharged below half their capacity to avoid damage. Accurate calculations are essential for practical applications, and users should expect to spend more than initial estimates due to these factors.
bobjenkins777
Sorry if this is in the wrong section (it isn't homework). I am trying to form a basic understanding of electricity. Right now I'm attempting to figure out how to calculate how long a battery will last with certain devices.
I might be completely off base but here's what I've got.
12volt battery rated at 250Ah
Device is rated at 115volts 10000 BTUs, that's 2931W-h
2931 / 12 = 244 amps (97.7% = of battery capacity)
Likewise
Battery capacity 12 x 250 = 3000watts
Using 2931 in one hour is 97.7 %
Not sure if this is correct was picturing a car battery and a portable ac unit
...one other
Battery rated at12volt and 12Ah
Device 1420mAh (iphone)
12000mAh battery at 12 volts
12000/1420 = 8.45
Does this mean I can charge the iphone 8.45 times off the other battery?
Also is there any calculation required when using a power inverter? (I would be using a power inverter to go from dc to ac in these examples. (Not that id ever want to power a 10000btu ac unit in my vehicle lol)
Thanks
The capacity rating (amp hour) for batteries is listed for a low current output. The capacity would be much less at a high load. I'm not sure at what current that 250 amp-hour rating would be realistic. The inverter would consume part of the power from the battery.
bobjenkins777 said:
12volt battery [...] Device is rated at 115volts
You must convert the voltage. In order to produce 1A at 115V you must use at least 115/12~10A of the battery. Simple customer grade voltage convertes rarely have efficiency better than 80% - so you must drain even more than 12 times higher current from your battery than you may make available to your device.
You have awfull mess with units: you mixed units of energy with units of power.
Thanks for the help! Still a bit confused but I'm getting there.
Also noted about difference between units of energy and power thanks
There is another point about 12V lead acid batteries. They should not be discharged to much below half of their capacity rating or they will not survive. So a 100Ahr battery can only be used as a 50Ahr battery. Crazy but true (advertising standards seem to be ignored here) and it can be an expensive mistake to ignore this. There are some batteries, referred to as Deep Cycle, which can be take lower but you would need to read the actual spec about how much you could take at the rate you need.
I totally agree with the foregoing comments about practicability and efficiency. the Ahr value is only a guideline and every other link in the chain will only serve to taqke things below this value. Tough. Do the sums and then spend much more than you calculated (as in all things).
You also have to keep in mind that real run-time is not linear with most lead-acid battery types.
http://www.thermoanalytics.com/docs/batteries.html
http://batteryuniversity.com/learn/article/calculating_the_battery_runtime
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
