Upward velocity of a block on a string
The discussion focuses on calculating the upward velocity of a block suspended from a spring after being pulled down and released. The spring has a force constant of 600 N/m and is initially stretched to 0.86m before being released. The conservation of energy principle is applied, with initial and final kinetic and potential energy equations set up. There is a debate about whether gravitational potential energy should be considered negative, depending on the reference point chosen. The final upward velocity calculated is 1.92 m/s, but adjustments for gravitational potential energy are necessary for accuracy.
ethex
The force constant of a spring is 600 N/m and the un-stretched length is 0.72m. A 3.2kg block is suspended from the spring. An external force slowly pulls the block down, until the spring has been stretched to a length of 0.86m. The external force is then removed, and the block rises. In this situation, when the spring has the contracted to a length of 0.72m, What is the upward velocity of the block?
KEinitial + Uinitial = KEfinal + Ufinal
0 + 0.5(600)(0.14)^2 = 0.5 x 3.2 x v^2 + 0
v = 1.92m/s?
Don't forget that gravity is working on the block too!
0 + 0.5(600)(0.14)^2 + (3.2)(9.8)(0.14) = 0.5 x 3.2 x v^2 + 0
Is this right?
Is this right?
Better, but should the gravitational PE be negative? (It looks like you're taking the zero reference for it at the unstretched spring level).
Thank you, that is what i am missing out.
