So the correct SI units for the quantity A are meters (m).
  • Thread starter Thread starter tommyboo
    Units
The correct SI units for the quantity A, derived from the equation A = √(R/TY), are meters (m). The units of R are kg m^3 s^–2, T are kg, and Y are m s^–2. By substituting these units into the equation and simplifying, kg and s^2 cancel out, resulting in √(m^2). This simplification confirms that the final unit for A is indeed meters. Therefore, the correct SI unit for quantity A is meters.
tommyboo
I am having a problem finding the correct SI unitsfor the quantity A?
In the equation
A=√(R/TY)
That is A equals the square root of R divided by TY
(not to good showing workings on the computer sorry)
, the SI units of the quantity R are kg m^3 s^–2, the SI units of the quantity T are kg and the SI units of the quantity Y are m s^–2. What are the correct SI units for the quantity A?
Mathematics news on Phys.org
In the equation
A=√R/TY
Both your notation and explanation are ambiguous.
Is the expression on the right side this?
\sqrt{\frac{R}{TY}}
or this?
\frac{\sqrt{R}}{TY}
The first one R/ty all square root. Do apologise for the bad format
Then, the units of A are meters.
To clarify gsal's answer...
You have the expression
\sqrt{\frac{R}{TY}}
Simply, insert the units for each variable (in place of the variables):
\sqrt{\frac{\frac{kg\cdot m^3}{s^2}}{(kg)(\frac{m}{s^2})}}
and simplify...
\sqrt{\left(\frac{kg \cdot m^3}{s^2}\right) \left(\frac{s^2}{kg \cdot m}\right)}
kg and s2 cancel out, leaving
\sqrt{\frac{m^3}{m}}
which is
\sqrt{m^2}
or, more simply m
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
