Leeson Reversible Electric Motor - 1/3 HP, 1725 RPM
The discussion centers on the Leeson Reversible Electric Motor, specifically its capability to reverse direction using a switch, which is crucial for knife making. The motor is a 1/3 HP, 1725 RPM, single-phase model with features like manual overload protection and a TEFC design. The user is seeking a wiring diagram to facilitate the installation of an on-off-on switch for reversing the motor's direction. Participants provide insights on wiring connections and suggest resources for diagrams, emphasizing the need to adjust specific terminals for proper operation. The user expresses a desire to continue knife making and shares details about their past experience and current setup.
yvesj
hi .i am new here
i like to know if this motor can't reversed using a switch from turning right to left .
i am a knifes maker [was] and my motor have to turn clock wise and counter clock .
thank you .
yvesj
More info please. Single phase? Capacitor start or split-phase? Do you have it in your possession or are you considering purchase? Do you have a diagram?
115/208-230 volts 6.4/3.2 amps 60hz
TEFC - Totally Enclosed Fan cooled - Electrically Reversible
Manual Overload Protection - Service Factor 1.15
NEMA 56 Frame - Flat Rigid base mount - 5/8" Diameter shaft x 1 7/8"
Class F Insulated - Ball Bearings w/low temp grease
Electric all purpose motor has 1/3 HP, 1725 RPM and rigid base. Also has capacitor start, 5/8in. shaft size and NEMA frame #56 for long lasting durability. 115/208-230 Volts. U.S.A.
thank you .
i was a knifes maker from 1993 to 2007
all i know is i did buy the same motor but a 1/2 .
the place that i got the motor did set up all wiring for me to connect it to my switch .
but because of my age and i had to move from my place i had to sell all my knifes making tools .
but i still have a few of my knifes to do the handle on them .
i need to reverse when i put the cutting on them .
i use a 6 inch stick on sand papper .
i use 6 because i have to up to 1200 gritt .you only get 1200 with the 6 inch sand papper .body shop supply
the motor i had the switch was a on-off-on .
now i do have some here .
no i did not buy the motor yet .
150.00 from amazon.com .192.00 at my door .not bad at all .
this is the best set up to but back a hedge on your knife if you know how to use wheel [6 ]800 grits]but after doing at least 1000 knifes you know how to use it .
i live in ontario Canada .
My bold and italicized. I guess I don't understand what the question is. It says it is reversible, so are you simply wondering how to install a switch or convenient method of reversing?
thank you .
yes i am looking at a good wiring diagram .i did find a fews of them on google .
like i said i do have a few brand new switch .on-off-on .
if i can't not do it i guess i will have get the motor to a electric motor shop or get a good electrician .
right now i was working on my new grainder .
now i have 2= 6 solid wheel .one on the right and one on the left .the wheel are made of aluminum then i use 6 stick on sand paper .this is really fast at changing the sand paper .
if you have a good wiring diagram for me i take a look at it and see if i understand it .
sorry .my spelling is bad .
is this the way to fix the wires on the switch
this is what i like to do .but 6 inch and reversable
You need to look at the wiring diagram for the motor and isolate the differences between CW and CCW. From there it should be reasonably easy to come up with switch wiring. IF the motor wiring is how I think it is then the back side of the switch you show in your attachment is probably right IF the terminals on the switch are how I think they are. It is not a matter of simply reversing the power leads. It involves changing the start winding leads relative to the run winding leads.
Amazon gave its number as Leeson 102931, if i found the same one
here's link for the Leeson connection diagram for that motor,
http://www.leeson.com/CnxDocRequest/PublishedPDF/00500544_145869_365.pdf
looks pretty standard
and its datasheet
http://www.leeson.com/leeson/searchproduct.do;jsessionid=3C3D4FB1A3E69185BB5A4F96FB579E5A?invoke=viewProductDetails&motorNo=102931.00&productType=0
does that look like right motor?
reversing wires T5 and T8 will reverse the motor,
but it is not clear to me from that drawing exactly what terminals you will need. Maybe ring lugs, maybe push-on blades...
is this any help?
lastly - might a washing machine motor do as well? One can get them free at most trashpiles.
thank .but i can't not open any of the 2 link you gave me .
has for a washing machine motor .
no .i need a motor with a fan at back because i am grainding steel .stainless steel .etc.etc .no wood what so ever .
only steel
they both open for me this morning
i got to them by going to
and entering that motor number in their quick search by number bar.
thank .that one did open .
here is a few knifes pictures that i have left here .
all my blades knifes are mirror polishe .and i do all my knifes cases .
a knife cust me about 55.00 material and i sell them 125.00 .
so there is not much money here .it take 5 hrs from the start to finish .complite ready to go
