How to derive impulse response from characteristic impedance
Impulse response can be derived from characteristic impedance (Zo), source impedance (Z_source), and load impedance (Z_load) in coaxial cables used for data transmission. Mismatching these impedances can lead to reflections that create errors in digital communication, particularly affecting the bit error rate (BER). Analyzing the effects of impedance mismatches requires understanding the receiver's input threshold and the impact of transmission line reflections. The first reflection is typically the most significant and correlates with the degree of mismatch. Understanding these dynamics is crucial for optimizing data transmission and minimizing errors.
edaffade
i have a coax cable that will be used in data transmission. i have measured the open and short impedance and then characteristic impedance(Zo) for the cable. Eventually I will have a transmitter with Z_source in one end of the cable and receiver with Z_load at the other end of the cable. Is it possible to derive impulse response as a function of Zo,Z_source and Z_load?
Unless the bit rate width is much longer than the coax line, it is not adviceable to to mismatch the source, line and termination impedance. Reflection will create a step change on the logic level and cause error.
In digital communication, you don't deal with standing wave and those, either you have it or you don't.
They all will be matched but i want to analyze the effects of mismatches on BER using impulse response to see how much mismatch is tolerable.
To do that, you have to know the threshold of the input of the receiver first, that is the most important thing. Then look up the transmission line reflection on step function. Usually only the first reflection step is the biggest and is proportion to the line and termination mismatch.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
