Solar panels and piezoelectric discs
Attaching solar panels in parallel with piezoelectric discs can lead to issues where the discs lose their effectiveness in the circuit. The solar panels may present a heavy load that shorts out the high-impedance piezoelectric discs, preventing them from generating voltage. Additionally, insufficient tapping on the discs could also contribute to their reduced output. Proper circuit design is crucial when combining different power sources to ensure they function harmoniously. Understanding the electrical characteristics of each component is essential for optimal performance.
shoes
I'm making a circuit using piezoelectric discs and i wanted to attach solar panels in parallel as well in order to increase amperes of the circuit. However, when put in conjunction the piezoelectric discs seem to have no effect on the circuit, when previously they had been contributing 5 or more volts. What is happening to the piezoelectric discs, why are they not working?
Perhaps you weren't tapping on the discs fast enough.
TURN DOWN VOLUME!
https://www.youtube.com/watch?v=Xuw9frP1GNo
In general, you can't simply connect different sources in parallel and expect them to work together. The solar panels are probably a heavy load on the high-impedance piezo, shorting them out.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
