Cross Product application problem
The discussion centers on calculating the magnetic force on an electron moving through a magnetic field. The magnetic force is determined using the equation FM = I x B, where I is the current (charge times velocity) and B is the magnetic field strength. The user calculated the magnitude of the magnetic force to be 1.28 x 10^-13 N, but was unsure about the direction, initially stating it was in the y-axis. Clarifications were provided regarding the need to specify the direction more accurately, suggesting that the positive value indicates a direction along the +y-axis. The right-hand rule was also mentioned as a useful tool for determining the direction of the magnetic force.
Asheram0
Calculating magnitude and direction of an magnetic force on an electron
Okay so the question says that the magnetic force (Vector)FM on a particle which is in a magnetic field is found by (Vector)FM = Vector I x Vector B.
Vector I = charge multiplied by the velocity of a charged particle
Vector B= the strength of the magnetic field (Measured in Tesla(T) ).
An electron accelerated from REST to the RIGHT, in a horizontal directed electric field.
The electron then leaves the electric field at a speed of 4.0 x 10^6, entering the magnetic field of magnitude 0.20 Tesla that is directed into the screen.
From the given information calculate the magnitude and direction of the magnetic force on the electron given that the charge on an electron is q= 1.6 x 10^-19.
All right, since we have to solve this in the cross product method I'm quite lost.
I take it we want to end up with something like this: (ax, ay, az) and b = (bx, by, bz)
giving us a x b = = (aybz − azby , azbx − axbz , axby − aybx)
So far i analyzed that
Vector I = charge of an electron (q = 1.6 x 10^-19) x velocity of a charged particle (4.06 x 10^6) (Since it says electron accelerates from rest to the right horizontally, i assume vector I is the x component?)
and for
Vector B = strength of the magnetic field in Tesla (0.20 T). (And since it says its directed into the screen, i assume its the z component? Right?)
So now we have
Vector I = 1.6x10^-19(4.0 x 10^6) = 6.4 x 10^-13
Vector B = 0.20
|I||B|sin90
|6.4x10^-13| x |0.20| sin 90 = 1.28 x 10^-13
So the magnitude is 1.28 x 10^-13 and the direction is in the y axis?
I defenitley think i hugely messed up somewhere, please help
Your calculations look fine to me. But you should take care when dealing with vectors and vector components to make sure that you specify directions completely. "in the y-axis" doesn't indicate if the direction is towards +y or -y. You should be able to write each vector in component form: ## x \hat{i} + y \hat{j} + z \hat{k}## .
I very much appreciate your reply, but since my answer is a positive value would it be correct in saying its towards the +y?
So i would do
|Vector Ix| = |vector I|cos 90°
6.4x10^-13 cos 90
=0
0.20 cos 90
=0
Sorry I am confused?
The sign of the result should depend upon your initial choice of axes, how the given values "lie" in that frame of reference, and any operations performed on those values. It's helpful to specify the coordinate system at the beginning and state the given values in terms of those coordinates. So for example, you might state that the +x-axis is chosen to coincide with the electron's direction of motion, and that the +z-axis is into the screen. The magnetic field is parallel to the z-axis and is directed towards +z. Or more concisely you could write:
Let: ##\vec{v} = 4.0x10^6 \hat{i}~m/s~~~~~and~~~~~ \vec{B} = 0.20 \hat{k}~T ##
So i would do
6.4x10^-13 cos 90
=0
0.20 cos 90
=0
If the result happened to have some odd direction that didn't coincide with any of the axes then you might want to write out the vector in ijk form. But if it coincides with an axis then it would be sufficient to specify which axis and which direction along that axis. For example, 1.28x10-13 N in the direction of the +y-axis.
Thank you very very much, it helped a lot! The right hand rule could also be applied in this question!
Kudos man!
