Will hydrogen gas displace copper in a copper(II) chloride solution?
The discussion centers on the reactivity of hydrogen gas compared to copper, particularly in the context of copper(II) chloride. It is established that according to the reactivity series, hydrogen is indeed more reactive than copper. This means that hydrogen gas can displace copper from a copper(II) chloride solution when bubbled through it. The reaction is supported by the equation CuCl2 + H2 --> Cu + 2 HCl, indicating that heating solid copper(II) chloride and passing hydrogen gas over it would yield copper and hydrochloric acid. The conversation emphasizes the general principle that gases, like hydrogen, tend to be more reactive than solids, reinforcing the idea that hydrogen's reactivity allows it to displace copper in chemical reactions.
reventon_703
According to the reactivity series, copper is below hydrogen.
In theory, hydrogen gas should be able to displace copper in a copper(II) chloride solution should the gas be bubbled into the solution, is this true?
Chemistry news on Phys.org
Is copper below hydrogen or hydrogen gas (H2)?
Touche... it is hydrogen.
But how can I find out if hydrogen gas is more reactive than copper? Gases are often more unstable and reactive than solids is it not?
I agree that Hydrogen is more reactive than Copper. Heat solid CuCl2 (below its temperature of decomposition) and pass H2 gas over it. I would expect:
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
