Relativistic Bohr Atom and MacLaurin Series
atomicpedals
By expanding a MacLaurin Series show that
E_{n}=\epsilon_{n} - \mu c^{2} = - \frac{w_{0}Z^{2}}{n^{2}}[1+\frac{\alpha^{2} Z^{2}}{n}(\frac{1}{k}-\frac{3}{4n})]
Through a lengthy derivation I arrived at
\epsilon_{n}=\frac{\mu c^2}{\sqrt{1+\frac{Z^{2}\alpha^{2}}{n_{r}+\sqrt{l^{2}-Z^{2}\alpha^{2}}}}}
I should add that k is what the text is using for the azimuthal quantum number, I used l in my derivation out of habit.
I've got no ideas where to go with this thing. I should take advantage of identites
\sqrt{1-x}=1-\frac{x}{2}-\frac{x^{2}}{8}+...
\frac{1}{1+x}=1+...
Do I need to make some aggressive substitutions?
I think I can make the following justifiable substitution
\epsilon_{n}=\frac{\mu c^2}{\sqrt{1+\frac{Z^{2}\alpha^{2}}{n'}}}
Where n' = n_{r} + \sqrt{l^{2}-Z^{2} \alpha^{2}}. But this still doesn't get me any closer to arriving at E_{n}=\epsilon_{n} - \mu c^{2} = - \frac{w_{0}Z^{2}}{n^{2}}[1+\frac{\alpha^{2} Z^{2}}{n}(\frac{1}{k}-\frac{3}{4n})] through a Maclaurin series.
Ok, I may be closer... using the substitution above to put E_{n} = \epsilon_{n} - \mu c^{2} in terms of n' I can calculate a Maclaurin series as follows
- \mu c^{2} + \frac{\mu c^{2} \sqrt{n'}}{\alpha Z} - \frac{n^{3/2} (\mu c^{2} \alpha Z)}{2(\alpha^{4} Z^{4})} + \frac{n^{5/2} (3 \mu c^{2} \alpha Z)}{8 \alpha^{6} Z^{6}} - ...
Am I on the right track to the final E_{n}?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
