Engineer vs Scientist: Differences Explained
Engineers and scientists have distinct roles, with engineers primarily focused on applying existing knowledge to solve practical problems, while scientists aim to discover new knowledge through systematic inquiry. Engineers design and create systems, materials, and machines, often working within constraints like budget and safety. In contrast, scientists engage in research to develop hypotheses and explore unknowns, contributing to theoretical advancements. There is significant overlap between the two fields, as engineers may need to innovate when existing solutions are inadequate, and scientists often rely on engineering principles for their experiments. Ultimately, both professions are essential, with each contributing uniquely to technological and scientific progress.
de.bug
Scientist Vs Engineer
hello
What is the difference between an Engineer and a Scientist?
engineers apply knowledge discovered by scientists.
Considering "scientist" is a more general term, it's a little hard to compare the jobs. In many cases an engineer can be a scientist, but a scientist is not necessarily an engineer. In the case of job descriptions for an employer (at least my employer) jedishrfu's description is generally accurate.
Engineer: "Engineers design materials, structures, machines and systems while considering the limitations imposed by practicality, safety and cost."
http://en.wikipedia.org/wiki/Engineer
Scientist: "A scientist in a broad sense is one engaging in a systematic activity to acquire knowledge. In a more restricted sense, a scientist is an individual who uses the scientific method."
http://en.wikipedia.org/wiki/Scientist
Where I work, an engineer is a scientist who makes practical application of what he knows.
Where I work,
engineers make money, scientists spend money.
One uses the symbol I for electric current and the other uses i.
When I first saw the title of this thread I thought the question would be "If a scientist and an engineer got into a fight, who would win?"
Thus, the engineer becomes immensely confused in a complex analysis class.
A mathematician, a physicist, and an engineer go to lunch one day. On the way back, they pass an open office an observe that there is a fire starting in the corner of the room.
The mathematician looks around, observes that there is a fire extinguisher on the wall and walks on. He is satisfied that the problem has a solution.
The physicist grabs his pocket calculator, estimates the size of the room, the amount of combustible material, etc, checks the tag on the fire extinguisher to see what size fire it can handle, and after some calculation, he too walks on. He has confirmed that the problem solution is at hand.
The engineer grabs the fire extinguisher and puts out the fire while the other two are fooling around.
This is the difference between the mathematician, the physicist, and the engineer.
observe their respective parking lots.
engineers are known for keeping their old jalopies running.
perhaps the distinction between living and inanimate is less clear to us ?
I'm going to hazard an educated guess (my Wife is a biotech research scientist, and I am a software engineer - amongst other things). This relates to our specific situations only.
Both solve problems. I think the big difference is the type of problem that they solve.
My Wife, as a research scientist, solves problems that currently have no solution, and are generally not 'practical'. An example could be 'It is generally though that green tea improves health. Exactly, at a molecular level, how does green tea do this?'. She comes up with a hypothesis and then sets out to prove this hypothesis, and hopefully finds a solution. her solution will be novel - no one will have come up with that solution in the past - actually, to correct that, no-one has published that same solution in the past (or she would have found it during the literature review). The hope (from her employers' commercial view) is that the novel solution can be patented and at some point money can be made from it.
I, as a software engineer, solve many problems every day to make my software achieve a certain goal or function. This is problem solving at a practical level. To do this I solve that problem(s), but I often rely on solutions that other people have already devised. In fact, that speeds up my job considerably.
A scientist would not be a scientist if they solved problems using existing solutions, as they would not be adding to human knowledge.
So the big difference, I think, is that an engineer solves practical problems that are not necessarily novel, and a scientist breaks new ground for human knowledge and understanding.
depends on what you're doing.
I did research on polymer electronics and on different processing techniques and their relation to device performance. We devised new methods for analyzing device structure and did theoretical calculations and experiments on thermal stability.
Does this sound like science, or engineering? Or both?
What did it say on your name tag? :P
Hi all, new here :)
I'm neither an engineer or a scientist but I think the difference in their roles can be roughly summarised as follows:
A scientist seeks to discover new knowledge.
An engineer seeks to apply existing knowledge.
So a scientist will try to discover the laws of motion and what causes electrical currents, whearas the engineer will try to use this knowledge (once it's been established) to invent cars, televisions, etc.
Nice :)
de.bug said:
What Is the Difference Between a Scientist and an Engineer?
The engineerer has a concrete problem and seeks a suitable solution.
The scientist usually has a concrete solution and seeks a suitable problem...
It is truer than it sounds!
11thHeaven said:
Hi all, new here :)
It's a little more complicated than that. (I know you said roughly, so I'm not disagreeing with you!)
There are a lot of engineers who are forced to discover new knowledge because the knowledge required to meet their goals does not exist. Otherwise, I'm not sure the phrase "Engineering Research" makes any sense (and I happen to do Engineering research).
So I would say that while blanket statements like that are useful, the reality is that the two blend together at the edges.
Also, a lot of scientists end up doing quite a bit of engineering in order to do their experiments (while most engineers don't do any science, in my opinion)
Engineers build things. Scientists discover things.
(As other people have said, there is a lot of overlap... in order to discover something, you often have to build a tool to help you, and in order to build something, you often need to discover something first. But I think the focus of the activity is the essential difference between the two.)
Engineers ask how something works
Scientists ask why something works
My (US Engineer) perspective:
Surviving an Engineering curriculum at the Bachelor's level will teach one how to solve problems. Getting through a Master's Engineering program in graduate school teaches one how to learn new subjects and deep analysis. The Ph.D. develops a skill in deep thinking and analysis, and to independently develop new insights.
In industry, engineers have constraints imposed upon them such as production schedules, finish dates, budget limitations, and limited resources (financial, physical, equipment, & personnel). The perception is that engineers are there to solve the problems of those conflicting constraints and "make it happen" to get the project completed or the products out the door in order to make revenue. It involves technical compromises, cutting corners but maintaining <whatever important criteria>, and occasional negotiating with a variety of stakeholders to accept other-than-specified parameters or changes of project scope or completion dates or budgets.
Not to seem disparaging in any way, but my experience with "scientists" is that they are often more narrow in scope and perception; focused on the task of discovery rather than the results; appear to value their worth via individual accolades (e.g., paper authorship) rather than an engineer's desire to show successful completion of projects.
My experience is that there is distinct difference in thought processes and motivations. But I think that there is a place for both in the world, and many times in the same company.
i think i understand what you mean.
even in applied sciences, the focus is on "making the device operational". The engineering mindset is "this device is operational. how do we make better without incurring horrendous losses?
I usually think of a scientist as being focused on devising experiments to understand nature, analyzing empirical data related to those experiments, and learning/creating theory related to understanding nature.
I think of an engineer as someone who may also perform experiments, but with an application in mind rather than purely understanding the nature of the world. They will analyze data to understand performance or characterize systems in the hopes that it will lead to practical uses. And they will learn/develop theory that may be mathematical or science in nature, but use this to explain or create man-made systems or use the information to benefit humans.
Like everyone seems to say, a scientist often uses engineering, and an engineer often uses science. I have found the people who excel in both are the ones I admire the most.
