Solving circuit using Laplace Transforms
The discussion revolves around solving a circuit to find the voltage across an inductor using both differential equations and Laplace transforms. The user initially obtained a solution for the current in the inductor using Mathematica but struggled to replicate this result with Laplace transforms. A key insight was provided regarding the voltage drop across the inductor, which helped the user correct their approach and achieve the correct answer. The user expressed intent to further solve the circuit by hand using differential equations and plans to seek additional help if needed. The conversation highlights the importance of careful attention to circuit equations in obtaining accurate results.
perplexabot
Hi all. I need to find the voltage across the inductor. I begin by solving for the current in the inductor. I first solved a circuit using differential equations (with mathematica) and achieved an answer for current in inductor of: iL(t) = E^(-5 t) (-0.75 + 1.25 E^(4 t)
Later, I tried to solve the same circuit using Laplace transforms and was not able to yield the same answer (or anything close). The original circuit and my approach for solving the circuit using Laplace transforms is attached as a pdf file. In the pdf file, I am attempting to solve for the current in the inductor. I get an equation for iL(s), however, when I take the inverse laplace, the answer looks nothing like my diff-eq iL(t). Please let me know where I am going wrong. Hints are preferred over answers. Thank you.
In your loop 2 equation the voltage drop across inductor should be (i2)sL.
WOW, you are so right. I can't believe I didn't see that. Thank you so much. I will give it another go. Hopefully I will not run into another error. Thanks again.
Thanks the_emi_guy. That simple fix gave me the exact answer.
You're welcome
I am now trying to solve the circuit by hand using differential equations. I have attempted it twice and went over it many times but have not achieved the correct answer (i am close though). I may upload my attempt tonight and hopefully you (or someone else) may help me with that too.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
