What is the proper form for Mohr's Circle (rotation of axes) calculation?
The discussion centers on the proper form of Mohr's Circle for calculating stress in a system undergoing rotation. Participants highlight that Mohr's Circle is applicable not just for stress calculations but also for 2-D symmetric eigenproblems. A key point of contention is the correct rotation matrix for transforming stress components, with differing interpretations from sources like foundationcoalition.org and Wikipedia. The conversation reveals confusion over the signs in the rotation equations, particularly regarding the sine terms. Ultimately, the participants agree that the discrepancies arise from differences in coordinate system conventions used in the references.
swampwiz
I'm getting conflicting information on the proper form of Mohr's Circle for the stress of a system at a rotation from nominal.
Actually it seems that Mohr's Circle is not a tool for just stress or moment if area/stress calculation, but in general for a 2-D simple symmetric form eigenproblem
[ K ]{ x } = λ{ x }
[ K ] → 2-D symmetric matrix
but this analysis seems to only be used in stress or moment if area/stress calculation, I will ask it here as a mechanical engineering topic rather than as a linear algebra topic.
Anyway, it seems that the rotation of axes for a static vector (i.e., the vector stays the same, only the coordinate system measuring it changes) has the form of
[ Ω ] =
[ C S ]
[ -S C ]
which is the transpose (and therefore inverse) of the rotation of a vector within a static coordinate system - and it is this minutiae of detail that I think its causing the problem.
So this rotation matrix becomes the eigenvector matrix for the previously mentioned eigenproblem, as a rotation from the principle aces representation (i.e., [ K ] as a diagonal matrix [ λ ] , which would be the eigenvalues.)
[ λ ] = [ Ω ]T [ K ] [ Ω ]
[ K ] = [ Ω ] [ λ ] [ Ω ]T
So from any given original [ K], the matrix for rotated axes [ K' ] would be
[ K' ] = [ Ω ] [ K ] [ Ω ]T
So going through the math, there is
let X = ½ ( kxx - kyy )
let Y = kxy
let I = cos( 2 θ ) X + sin( 2 θ ) Y
let J = - sin( 2 θ ) X + cos( 2 θ ) Y
λAVG = ½ ( kxx + kyy )
kxx' = λAVG + I
kyy' = λAVG - I
kyy' = J
Or at least that it what I come up with - and seems to correlate with that referenced @ foundationcoalition.org - http://www.foundationcoalition.org/resources/en/engr214/Chapter5.pdf (page 5 in the document, or 109 per the header.) However at Wikipedia at an article for moments of inertia - http://en.wikipedia.org/wiki/Second_moment_of_area#Axis_rotation_in_the_xy_plane - the rotation has the signs of the sin terms reversed, which would indicate that the rotation matrix should be inverted - even though that article has the proper rotation matrix!
So my question is which if these references is correct? The foundationcoalition.org document (which my analysis seems to be in agreement), or the Wikipedia article?
If the Wikipedia is, as I suspect incorrect, I will change it.
Wiki is correct
look at equation 5.11 of your first (pdf) reference. There is a leading minus sign to the first term that I think should not be there.
Studiot said:
Wiki is correct
If that is the case, then sin term in EQ 5.10 should be negative as well.
I've researched at least 2 books that supports my contention (Foundations of Solid Mechanics, Fung; Intermediate Mechanics of Materials, Barber), so I am going to consider my contention correct and will change the Wikipedia article.
Yes that is correct the sin term is negative in equation 5.10.
But if you look carefully at the directions of the contributions Wiki and Foundation are referring to different situations.
I have sketched the stress systems comparable for each, rather than try to compare a moment of inertia with a stress. Note that the shear directions are reversed.
OK, so it appears that this a coordinate system issue. I've always thought that the rotation of axes should be as I've described.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
