Understanding the Role of Viscosity and Elasticity in Dissipative Thermodynamics
  • Thread starter Thread starter muzialis
    Thermodynamics
The discussion revolves around understanding the thermodynamics of dissipative systems, specifically applying Onsager's relations to a one-dimensional dashpot and a series system of a spring and dashpot. The equation derived indicates that in a dashpot, the free energy is zero, leading to a relationship between dissipation and generalized force that aligns with Newtonian viscosity. However, confusion arises when trying to apply the same principles to a system with both a spring and a dashpot, particularly regarding the generalized force for the dashpot, which responds to rate rather than displacement. The key point is the distinction between the elastic response of the spring to displacement and the viscous response of the dashpot to the rate of displacement. Clarifying these concepts is essential for resolving the confusion regarding the application of the equations in the series system.
muzialis
∂Hello there,
I am trying to understand the basics of thermodynamics of dissipative systems.
In the attached paper equation (2.13) is derived using the concpt of free-energy and Onsager's relations
It says that, restricting to only one generalized coordinate
∂V / ∂q + ∂D / ∂q' = Q
V being the free energy, D the dissipation function as defined by Onsager's principle, Q the generalized force associated to the generalized coordinate q, and the apex deoting differentiation wit respect to time.
Trying to make sense, I applied to a one-dimensional dissipative sisyem, a dashpot.
Indeed, for a dashpot V = 0 identically, so the equation suggests (D defined as D = 0.5 b q'^2)
b q' = Q
which makes perfect sense (Newtonian viscosity).
If I try to do the same with a spring and dashpot in series, having q1 and q2 as coordinates representing the extension of the spring and the dashpot, I end up with a system ,
∂V / ∂q_1 + ∂D / ∂q'_1 = Q_1
∂V / ∂q_2 + ∂D / ∂q'_2 = Q_2
The first makes perfect sense, expressing the fact the force in the spring equals the applied force.
The second should say the same for the dashpot, but I struggle to understand what Q_2 is. Should be a force conjugate to the displacement of the dashpot, but the dashpot react to an applied rate, not to an applied displacement.
Where am I going wrong?
Thanks
Science news on Phys.org
Did you ever figure this out? I'm guessing from the title of the link you gave that there is both viscosity and elasticity involved. Elasticity is the reaction to the applied displacement, viscosity to the applied rate of displacement.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
