Youngs modulus vs Ultimate tensile strength
Ultimate tensile strength (UTS) is the stress level at which a material fractures, while Young's modulus measures the material's stiffness in the elastic region. The values for copper, with a UTS of 245 MPa and a Young's modulus of 131,000 MPa, illustrate that these properties are fundamentally different despite sharing the same units. Theoretical strength predictions suggest UTS should be between E/20 and E/5, but actual measured UTS values are often lower due to structural defects. This discrepancy highlights a general trend where UTS is less than Young's modulus for most materials. Understanding these differences is crucial for accurate material analysis and engineering applications.
Amlesh
In case FEA we consider ultimate tensile strength to decide whether component will fail OR pass why ultimate tensile strength is lesser than youngs modulus? Example for copper UTS is 245 MPa n youngs moduls 131000MPa. Why it is like this?
Regards,
Amlesh
The UTS is the stress at which the component/material will fracture.
The Modulus of Elasticity or Young's modulus is the ratio of the stress to strain for the elastic region of the stress-strain curve of the material.
Where did you get those values for copper?
Rock,
Many thanks for quick reply.
By the way, I got this coper value from one of our vendor.
The compressive strength and young modulus are different quantities, measuring different properties. They do have the same unit but they are still different. So comparing their values is a little meaningless.
Like saying that the torque of a given force (in Nm) is less (or more) than the work done by the force over a given distance (also in Nm).
I am not saying that is not interesting to look at the values, as long as you know their meaning.
Actually the so called theoretical strength of many metals was found to be between E/20 and E/5, (if I remember correctly) where E is Young's modulus. These are calculated from crystal structure and bond strength, for a perfect crystal. So it seems that there is a general tendency to have UTS "less" than E, in value.
The measured UTS values are a lot less than predicted by this rule of thumb, due to defects in structure.
You can think of Young's Modulus as the elastic stress when the strain is 1 (i.e. the length of the object has doubled). Not many materials can double in length and remain perfectly elastic, so the UTS of most materials is numerically less than E.
Likes 1 person
Dear All,
Thanks for quick reply.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
