Question on special case reactions between metal and acid
Copper reacts with hot, concentrated sulfuric acid to produce copper (II) sulfate, sulfur dioxide, and water due to the strong oxidizing properties of sulfuric acid. This reaction occurs because sulfuric acid can oxidize copper, facilitating the formation of copper (II) sulfate while releasing sulfur dioxide gas. Similarly, when copper reacts with hot, concentrated nitric acid, it forms copper (II) nitrate, nitrogen monoxide, and water, again due to the oxidizing nature of nitric acid. Other metals that can react with hot, concentrated acids to produce gases include those higher in the reactivity series, which can also yield gases other than hydrogen. Strong oxidizing agents commonly used in these reactions include nitric acid and concentrated sulfuric acid, with perchloric acid being a less common option. Understanding the reactivity of metals with acids is essential for grasping the principles of oxidation-reduction reactions in chemistry.
xtprtpr
I am a GCSE student and I am wondering why copper metal reacts with hot, concentrated sulfuric acid to produce copper (II) sulfate, sulfur dioxide, and water. Copper also reacts with hot, concentrated nitric acid to form copper (II) nitrate, nitrogen monoxide and water. Why do these reactions work? What other metals react with hot and concentrated acids this way to produce gases(not hydrogen gas)? Any help would be appreciated. I am just a GCSE student so pardon me if I do not understand certain explanations. Thanks!
Chemistry news on Phys.org
Oh I see. What acids are strong oxidizing agents though?
Of those commonly used nitric and to some extent concentrated sulfuric. Of those less often used - perchloric acid.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
