Calculating required pressure to maintain flowrate
  • Thread starter Thread starter bugatti79
    Flowrate Pressure
To maintain a flow rate of 0.5L/min through a 1mm diameter hole, significant pressure is required due to the viscosity of the oil, especially under gravity. The discussion highlights that treating the scenario like a restriction orifice can provide insights, considering factors like discharge coefficients and Reynolds number. The complexities of viscous flow mean that simple hand calculations may not yield accurate results, as viscosity contributes to shear forces at the wall. The conversation emphasizes that the effects of viscosity are crucial in low-speed scenarios, making inviscid flow assumptions inadequate. Overall, a robust understanding of fluid dynamics principles is necessary for accurate pressure calculations in this context.
bugatti79
Folks,
I seek just a very rudimentary idea of what pressure is required to pump oil through a very small hole of 1mm diameter to maintain a flow rate of 0.5L/min. See attached.
I would imagine that under gravity that the flow rate would be very low because of the viscosity of the oil thus to maintain a this flow rate significant pressure would be required to push it through. Let's assume the oil container bore is 10mm diameter.
Any thoughts?
Regards
Can treat it like a restriction orifice. It will consider the discharge coefficients depending on thickness, viscosity, temperatures, diameters, reynolds #, etc. to give more accurate #'s
The head pressure required might make your container quite high?
Well I have come across this link
http://en.wikipedia.org/wiki/Orifice_plate#Incompressible_flow_through_an_orifice
but it is only for inviscid flow, I am interested in viscous flow like oil. I guess a simple hand calculation is not possible...?
Basically I would like to argue the point that a very large pressure pump would be required to pump oil through a 1mm diameter at a rateof 500ml/min...
I think you're confusing what is involved in the viscous and invicsous flow assumptions. Any value of viscocity is going to make a contribution to the shear forces at the wall due to viscosity of the fluid. Making the assumption of inviscid flow depends on what area of the flow you are interested in. If you're after a value inside the boundary layer, close to the wall, then you might need equations to describe viscid flow. Otherwise their contributions to the flow somewhere else is usually negligible in problems like this one.
It really depends on the Reynolds number of the flow. For example, Air at high speeds is going to have more of an effect on the flow than oil at low speeds, even though oil has a much higher value than air.
bugatti79 said:
Folks,
Any thoughts?
Regards
Well I would be interested in low speeds,so it looks like a simple hand calculation is not possible?
For a simple/rough and incompressible calculation using bernoullis principle:
http://en.wikipedia.org/wiki/Bernoulli's_principle
E.g. (v1^2)/2 + g*z1 + P1/p = (v2^2)/2 + g*z2 + P2/p
This obviously ignores the losses but gives an idea. Also, assuming your pouring to atmosphere and using conservation of energy to get the initial velocity (pVA)in=(pVA)out
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
