Moment of Inertia of a hollow beam inside a rubber shell
The discussion focuses on calculating bending and shear stresses in hollow beams, specifically regarding a steel shell encased in rubber discs for impact loading. The user initially questions whether to consider only the steel shell's moment of inertia in their calculations, given that the rubber is meant to distribute loads more evenly. However, they later realize that the rubber's contribution to the overall moment of inertia, particularly in terms of rotational inertia, is significant due to its mass and radius. The conversation highlights the complexity of composite materials, noting that while the rubber may not significantly contribute to bending stress, it does affect the overall stiffness and rotational inertia of the system. Ultimately, the user seeks clarity on how to incorporate these factors into their calculations.
MaxOtis
Hello guys,
I am calculating Bending and Shear stresses in hollow beams. We have a particular kind of shell that we use for impact loading, so we put rubber discs around the steel shell.
So my question is, how will it affect the moment of inertia ? Since I know that the rubber discs will resist to the stress, can I consider only the steel shell in my calculations ?
What do you guys think ?
Thanks.
You need to provide considerably more information for anyone to make a sensible comment.
In particular why do you think the disks act compositely with the steel?
Thanks for your reply,
I attached a pdf of an impact roller.
The roller is use in conveyor to carry ore/material. More specifically, we use it where we drop the material on the belt.
The reason why we use rubber is to make the load more uniform on the steel shell, without it, their would be huge concentrations of load on small area on the shell and it wouldn't resist a day.
Even with the rubber, the quantity of load supported by the steel shell is obviously the same, and if we make a Free Body Diagram of only the steel shell, I could take the Moment of Inertia of the shell without rubber. Am I right?
EDIT: After consideration, it doesn't really make sense to consider the load only on the steel shell. I am out of idea. The minimum Inertia would be in between 2 rubber discs, but since the load are applied on the top of the discs, I am not sure whether it is assumption to use this value of Inertia for my calculations.
Any Idea ? :rolleyes:
OK I think you are talking about rotational inertia.
My earlier comment was directed on the assumption of structural bending of the roller.
For rotational inertia the rubber will add significant mass at a significant radius to greatly increase the rotational inertia about the shaft axis.
I assume there is no slip on rotation.
In terms of adding to the shaft stiffness against bending I doubt that even if the rubber was sufficiently shrunk on to the steel to act compositely it would attract much stress, despite its position) simply because of the huge difference in elastic moduli.
Is this making progress?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
