Question for pressure engineer about cascading gas
The discussion centers on cascading gas from a high-pressure vessel to a lower-pressure vessel to increase the latter's pressure from 2,000 psig to 2,700 psig. The user has calculated a cascade time of approximately three minutes using compressible mass flow rate equations, neglecting factors like temperature and pressure drop. Responses indicate that while three minutes may seem reasonable, the flow rate through a 1-inch pipe could be low, potentially affecting the time required to achieve the desired pressure increase. Additionally, the pressure drop in the high-pressure vessel as gas is depleted could further complicate the flow rate. Overall, further calculations may be necessary to confirm the accuracy of the initial estimate.
steves1080
Say I had a high pressure vessel with a volume of about 1400 cubic feet and pressurized to 5,000 psig. Now say I had a lower pressure vessel with a volume of 1800 cubic feet (slightly higher) and pressurized to 2,000 psig. The goal is to "cascade" gas from the higher pressure vessel to the lower pressure vessel in order to get the lower pressure tank up to 2,700 psig. The gas would flow through a pressure regulator (with max output set point of 2,700 psig) fully opened up. The gas going into the lower pressure tank flows through a 1-inch diameter pipe and only about 30 feet in length. I've already done the calculations using the compressible mass flow rate equation for choked flow using ideal gas law assumptions and using the Cv of the regulator to determine the magnitude of the choke point. I neglected temperature, enthalpy, and pressure drop affects, and stuck to the basic physics behind it. But the answer I got for how long it would take to cascade that much gas was ~3 minutes. I am looking for an experienced pressure systems engineer to let me know if this sounds reasonable or if I need to do some more calculations. It would also be helpful to know what type of number to expect if this seems way off. For some reason I was expecting it to take much longer, but I don't have too much experience with high pressure gases. I've run my numbers multiple times, so I think I am correct.
I should note that the gas is nitrogen, so it's basically just air
The flow of air through a 1" pipe will be relatively low in volume, and considering the size tank you have, there's quite a lot of it required to raise the pressure by 700 psi. Also consider that the pressure in the first tank will drop as it's volume is depleated by the flow to the second tank, thus reducing the flow rate. As an off the cuff guess I'd say 3 minutes sounds reasonable.
I haven't crunched any numbers, so take that for what it is.
Thanks for the response. I did crunch some numbers, but the problem is that I have no way of gauging what seems reasonable. 3 minutes sounds possible to me, but on the other hand that it a lot of volume to fill that quickly.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
