Eigenvalues of a compact positive definite operator
SVD
eigenvalues of a compact positive definite operator!
Let A be a compact positive definite operator on Hilbert space H.
Let ψ1,...ψn be an orthonormal set in H.
How to show that <Aψ1,ψ1>+...+<Aψn,ψn> ≤ λ1(A)+...+λn(A), where
λ1≥λ2≥λ3≥... be the eigenvalues of A in decreasing order.
Can someone give me a hint?
Both the left and right expression look like tr(A).
Try induction.
Do you know that
\lambda_1=sup\{&lt;Ax,x&gt;~\vert~x\in H,~\|x\|=1\}
If you know this, then the case n=1 should be easy. Can you find an argument to deal with the other cases?
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
