Understand Alternating Current: Electric Flow & Energy
Alternating current (AC) involves the electric current pulsating back and forth rather than flowing in one direction, which can be confusing when trying to understand energy transmission. The analogy of flowing water is often used to explain electricity, but it breaks down when discussing AC, as it is more akin to ocean waves. The phase angle in AC represents the relationship between voltage and current, indicating how they can be out of sync despite both being present. Understanding AC requires a grasp of both voltage and current, as they can be mathematically represented with vectors. A deeper exploration of the fundamentals of electricity is recommended for a clearer understanding of these concepts.
mohammad_adam
So I get the general idea of electricity being the flow of charge (or lack of electrons) but when it's alternating I don't quite understand what's going on. So the current is just pulsating back and forth? How do they refer to this bring the transmission of electrical energy?? Isn't it essentially not even technically "flowing"?
Are there any other things that go back and forth that can transfer energy from one place to another?
What about when you rub two sticks together to light a fire?
Hmmm I guess I see what u mean, not entirely, but sort of.
Is current meant to be looked at as flowing water? Flowing water which is sent down kilometers of transmission lines, allowing anyone to hook up and draw some water from it? If the analogy is appropriate, then how does AC fit in?
Also, y does current (and voltage) have a phase? What does that angle represent? Is it the position of a given amplitude along a sinusoid?? I've never fully wrapped my head around that
The analogy of water to current is VERY problematic and breaks down in the sense in which you are exploring electricity. Google "electron drift"
Not really - it is a way to hep students learn about simple electric circuits.
By analogy, the water source would be ocean waves.
But it starts to get very shaky.
The changes in electric potential (voltage) do not have to in sync with changes in the electric current. Why would you expect it to?
A varying voltage can be represented as the sum of sinusoids.
A sinusoid can be represented as the vertical position of the tip of an arrow turning in a circle.
http://en.wikipedia.org/wiki/Phasor
The phase angle is the angle the arrow makes to some reference direction.
In this case, the arrow represents voltage and the reference direction is the current.
You may be leaping into the subject too far and too quickly if you really want to understand it. I suggest you read around Wiki and Hyperphysics sites. This is not a very 'intuitive' subject and you need to build up on basics first.
I agree lol. I duno how I did 3 years of electrical engineering. But then I guess not too many ppl give enough of a damn to look into these things deeply, they just take things for face value, memorize a bit of this n a bit of that, and voila u got urself and engineering degree. I hope to learn more deeply than that, thanks for all the help guys, I guess I'll build up on the basics first and then return to physics forums.
You did 3 years electrical engineering at college level?
I was answering at senior secondary-school level :)
Many people look into these things deeply, it's just that people interested in fundamental concepts tend not to become engineers. <ducks>
You probably want to review the basics from the physics perspective rather than the engineering one.
That's very true... I guess engineering being the application of science doesn't allow room for pondering the technical nature of things down on the small scale. Its Definitely some mind blowing stuff to attempt to understand though. There's probably no better hobby on the planet.
It's pretty much why all of us are here, yes :D
I'd go so far as to say that it is the best purpose for self-aware entities... but that's a personal philosophy.
The simple example is think of the piston on an old steam loco - the piston goes back and forth and the connecting rod ( conductor - sorry for the dual rr meaning) - pushes - then pulls (2 directions) , delivering energy TO the wheels in each direction - power delivered in one direction - from the piston to the wheels. As for the water analogy - I do tend to like it for BASIC descriptions - and a closed hydraulic system can be used to demonstrate may principals.
The basic of confusion comes from thinking of ONLY current - in electrical power - we need to discuss Voltage and Current - and in AC we can mathematically represent these with vectors. so if Current is flowing in the Positive direction ), and the Voltage is Positive - it is the same direction of power flow as Current in the Negative Direction and Voltage is Negative.
As for phase - it has many meanings depending on the specifics of the discussion - for a single wave for it can be relating to apaecific point in the the wave, in power it typically details the relative angle of two waveforms - thay can be both voltages - both currents, V and I - etc.
