What is Zero Action? What is zero action?
  • Thread starter Thread starter Sunfire
    Zero
Zero action refers to the concept that in unconstrained motion, the action is always zero, while in constrained motion, it is minimal but never zero. The principle of least action suggests that motion occurs under constraints to minimize the difference between capability and actual motion. Free fall is discussed as a constrained motion, where the action can be zero at specific points, such as halfway down. The significance of zero action lies in the minimization of action rather than its absolute value, which can vary based on potential energy adjustments. Overall, the discussion emphasizes understanding the implications of action in physical systems and the conditions under which it can be constant.
Sunfire
What is "zero action"
Hello All,
I have been reading this thread, trying to understand the concept of action. There is one very intriguing (to me) statement in that thread:
"So your action is the difference between your capability of motion and your actual motion.
The principle of least action says that there is no difference without some sort of constraint - in which case the motion will be such that this difference is as small as possible." /by Simon Bridge/
Do I understand this correctly - the action is always zero for unconstrained motion; and never zero (but minimal) for constrained motion. Is this reasoning true?
Is free fall a constrained motion? Because the action is zero only at y = y_initial / 2, y is the vertical position.
Perhaps someone has an idea...
Thank you, UltrafastPED; I read the chapter you suggested. Quite a few good points there. I am still having trouble to understand something, though. What is "zero action"? Does it have any significance?
In the chapter by Feinman, the free falling body moves downwards and its lagrangian changes from negative to positive. At some point (half the initial height), it becomes zero. Does this zero lagrangian have any physical significance?
The actual value of the action is not important, only that it is minimized. The value of the action can be made arbitrarily large or small simply by adding a constant offset to the potential.
Likes 1 person
This makes perfect sense.
What if, in a system,
Ep = f(x) - C, C is arbitrary constant
Ek = f(x)
for all x.
Then L = Ek - Ep = C for all x, thus the action remains constant. Does this ever happen?
In principle, it is possible, but I have never seen such a system. Usually the potential energy is a function of the generalized positions and the kinetic energy is a function of the generalized velocities, so I haven't seen a case where they are the same functions like that.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
