Why Isn't dv/dy Zero in Stoke's First Problem?
  • Thread starter Thread starter member 428835
In Stokes' first problem, the flow is initially at rest until one wall moves in the x-direction, creating a velocity profile. The conservation of mass for incompressible flows indicates that the divergence of the velocity vector must equal zero, leading to the conclusion that ∂v/∂y is zero. However, this does not imply that there is no velocity in the y-direction; rather, it indicates that the y-direction velocity (v) remains constant and equal to zero throughout the flow. The x-direction velocity (u) varies with y, which is why ∂u/∂y is not zero, reflecting the shear stress interactions between fluid layers. Thus, the presence of y-direction velocity is clarified by the understanding of fluid dynamics and shear stress in Newtonian fluids.
member 428835
hey pf! please read this, it's honestly pretty easy although long to read.
in stoke's first problem, we have parallel flow initially at rest and then, instantaneously (i know, unrealistic) one wall starts to move in the x-direction with no acceleration (yes, it magically becomes a velocity). the y-direction is perpendicular to the x direction and is directing toward the other wall. the z-direction is coming "out of the page".
okay, now time for the question.
conservation of mass for incompressible flows yields: $$ \nabla \cdot \vec{U}=0 \Rightarrow \frac{dv}{dy}=0$$ since \frac{du}{dx}=\frac{dw}{dz} are identically zero. my question is, why isn't \frac{dv}{dy} identically zero? i know it equals zero from the above, but how does it exist at all? how is there velocity in the y direction?
it makes sense to me that the other two are zero by inspection, but why not y? to me it seems \frac{du}{dy} would not be zero but that all others would be. please help me understand how there exists y-direction velocity (y )
thanks ahead of time!
Your intuition and majority of statements are accurate, just a little variable terminology confusion:
U = u i + v j + w k
For your example: 0<= u <= V where V = wall velocity; v = 0; w = 0
Therefore ∂v/∂x = ∂v/∂y = ∂v/∂z = 0 and ∂w/∂x = ∂w/∂y = ∂w/∂z = 0
∇ dot U = ∂u/∂x + ∂v/∂y + ∂w/∂z = 0 (conservation of mass for incompressible flow)
Since flow is constant in the x direction for a given y, then ∂u/∂x = 0
So indeed ∇ dot U = 0 based upon the above partials.
In summary, since v is the fluid velocity in the y direction, it is zero. Hence ∂v/∂y = 0.
The only fluid flow is in the x direction, and since u varies as a function of y and is not constant, then ∂u/∂y is not zero. The molecules of each horizontal layer collide and change the molecular velocity in the adjacent horizontal layer. For instance for a typical Newtonian fluid
∂u/∂y = - fluid shear stress / viscosity
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
