What is the construction method for creating complex numbers of any dimension?
The discussion centers on the construction of hypercomplex numbers and their properties compared to complex numbers, quaternions, and octonions. It highlights that these hypercomplex numbers can be defined in any dimension and maintain commutativity and associativity in addition and multiplication, with all non-zero elements possessing multiplicative inverses. However, participants argue about the validity of these constructions, pointing out inconsistencies and questioning the mathematical rigor behind the claims made. References to established mathematical principles, such as finite dimensional division algebras and the work of Forbenius, are made to challenge the assertions presented. Ultimately, the conversation reveals a deep divide in understanding the nature and classification of these hypercomplex systems.
Owen Holden
Extensions of complex numbers are available for 2^n dimentions.
For example:
1. (a+bi+cj+dk) = ((a+bi)+(c+di)j)
where: i<>j, i^2=j^2=-1, ij=ji=k, ik=ki=-j, jk=kj=-i, k^2=+1.
Unlike quaternions, these hypercomplex numbers are:
commutative and associative wrt addition and multiplication, distributive with addition, all multiplicative inverses exist except zero and zero divisors.
And, the elementary functions, e.g. e^(a+bi+cj+dk) are available.
2. (a+b(i2)+c(i3)+d(i4)+e(i5)+f(i6)+g(i7)+h(i8)) =
(a+b(i2)+c(i3)+d(i4)) + (e+f(i2)+g(i3)+h(i4))(i5).
where: i2<>i3, i2<>i5, i3<>i5, (i2)(i3)=(i4), (i2)(i5) =(i6), (i3)(i5)=(i7), (i4)(i5)=(i8).
All other product combinations are easily found granting commutativity and associativity. e.g. (i6)(i4)= (i2)(i5)(i2)(i3)= -(i3)(i5)=-(i7).
Unlike octonions, these hypercomplex numbers are:
e.g. e^(a+b(i2)+c(i3)+d(i4)+e(i5)+f(i6)+g(i7)+h(i8)) are available.
Quaternions and Octonions, etc., are produced within these hypercomplex numbers via special product functions.
Complex numbers of any dimention can be constructed in this way.
Whatdoyouthink?
Mathematics news on Phys.org
That you've not proven any of the things you say are true. That makes it bad mathematics. The things you are producing are called algebras and they'vebeen studied for many years.
Oh,and you're also wrong:
i^2=j^2
hence
i^2-j^2=0
since everything is commutative this implies
(i-j)(i+j)=0
since there are no zero divisors it follows that i+j=0, since i=/=j, that is j=-i. so it isn't an extension after all.
The proofs follow from the definitions, shall I do the arithmetic for you as well?
Please see my above counter example to your claims.
Please look up "finite dimensional division algebras" to see what you should know already before telling me I'm wrong.
(As an extra hint, Forbenius proved what you're trying to do is impossible in 1877, I just found out)
Ah so you're not claiming these are divison algbras, my mistaek. YOu're just saying they are algebras. SO why aer you claiming these are "like" the complex numbers?
All you've done is take some ring and add in inverses to the non-zero divisors? So? I was assuming you were doing something that wasn't well known and been aroudn for many years.
i^2=j^2
hence
i^2-j^2=0
(i-j)(i+j)=0
Of course there are zero divisors! They are numbers that are specifically defined.
(i-j) is a zero divisor because there is a non-zero number, (i+j), which when multiplied by (i-j), becomes 0.
"(As an extra hint, Forbenius proved what you're trying to do is impossible in 1877, I just found out)"
Nonsense!
Like I said, I misunderstood and thought you were trying to define a division algebra "like C".
What you've got is an algebra, two dimensional over C. See the Wedderburn structure theorem for a classification of all semi simple ones. If they are not semisimple have you found the Jacobsen radical of it?
Associative (and commutative) algebras have been studied for many years and exist in arbitrary dimension.
Just forget this (my comments), ok. Sorry if I'm sounding harsh, but there are many algebras out there, and I can't see for the life of me why you think these deserve to be called the "proper" generalizations of complex numbers, and think Hamilton and Cayley were wrong, whatever wrong may mean in this context.
For hypercomplex numbers (a+bi+cj+dk), k^2=+1.
For quaternions (a+bi+cj+dk), k^2=-1.
Which is it? Obviously the k of hypercomplex numbers is different from the k of quaternions.
Don't you see the inconsistency?
For me k^2=+1 and kHk=-1, i.e. H is the Hamilton product applied to hypercomplex numbers.
The same things apply to Cayley numbers and to further extensions, 16-valued etc., of the Hamilton product.
No. Different systems, different results.
What? The only inconsistency is that you think those k's ought be the same thing.
Hamilton produced a division algebra, you haven't. They are different things, that is all, just as there (infintely) many Calyely algebras with generators 1, i,j,k with the expected properties except that k^2=(-)p for some prime p, which are of special intererst in number theory and physics.
There is also an algebra R[f,g,h] with the relations f^2=g^2=h^2=1, and fg=gf=h, it is the group algebra over R of C_2 x C_2. So what?
All you're doing is defining some 2-d complex or 4-d real algebra and claiming they are "hypercomplex", as if there was something special about them in relation to the complex numbers.
Extending the number system from complex numbers, (a+bi), to 4-D
hypercomplex numbers, (a+bi+cj+dk), leads to a multiplication
table such as;
(A) i^2=j^2=-1, ij=ji=k, k^2=+1, ik=ki=-j, jk=kj=-i.
Sir W. Hamilton introduced 'quaternions' by presenting the
multiplication table;
(B) i^2=j^2=-1, ij=k, ji=-k, k^2=-1, ik=-j, ki=j, jk=i, kj=-i.
Clearly list (A) is incompatable to list (B).
Is k^2=-1 or is k^2=+1, it cannot be both. k cannot be the
same entity in both cases. I believe Hamilton's algebra
would be consistent with hypercomplex numbers if he had
introduced a Hamilton (H) product such that;
iHi=jHj=-1, iHj=k, jHi=-k, kHk=-1, iHk=-j, kHi=j, jHk=i, kHj=-i
where i,j,k are the same hypercomplex numbers as in (A).
It was misleading and incorrect for Hamilton to consider that
quaternions are entities at all. There are no such things as
quaternions. There is a Hamilton algebra which deals with
the concepts that Hamilton wanted to deal with but they are using
hypercomplex numbers in the context of the Hamilton product (H).
In the 8-D case, (a1+a2i2+a3i3+a4i4+a5i5+a6i6+a7i7+a8i8)
multiplication leads to the entries;
(C) (i2)^2=(i3)^2=(i5)^2=-1, (i2)(i3)=i4, (i2)(i5)=i6, (i3)(i5)=i7,
(i4)(i5)=i8, (i4)^2=+1, (i6)^2=+1, (i7)^2=+1, (i8)^2=-1.
Sir A.Cayley introduced 'octonions' by presenting a multiplication
list containing;
(D) (i2)^2=(i3)^2=(i4)^2=(i5)^2=(i6)^2=(i7)^2=(i8)^2=-1.
Again (C) and (D) are incompatible. (i6)^2=+1 from list (C),
contradicts (i6)^2=-1 from list (D). Cayley makes the same
mistake for 'octonions' that Hamilton made for 'quaternions'
There are no such things as octonions. There is a Cayley algebra,
with a Cayley product (Ca), dealing with 8-D hypercomplex numbers
which expresses what Cayley means.
(i2)Ca(i2)=(i3)Ca(i3)=(i4)Ca(i4)=(i5)Ca(i5)=(i6)Ca(i6)=
(i7)Ca(i7)=(i8)Ca(i8)=-1.
Thread locked.
11K
