What is the solution to the equation y''' + 4y'' + 4y'=0?
  • Thread starter Thread starter RadiationX
    Approach
To solve the equation y''' + 4y'' + 4y' = 0, the characteristic equation r^3 + 4r^2 + 4r = 0 is derived. This approach treats the third-order ordinary differential equation similarly to a second-order one. The discussion confirms that this method is valid for finding a solution. Participants express agreement on the effectiveness of this technique. The conversation concludes with a shared understanding of the solution process.
RadiationX
what method do i employ to solve this?
y''' + 4y'' + 4y'=0
does the above lead to something like this?
r^3 +4r^2 +4r=0
Approaching this problem like if it was a 2nd order ODE yield a solution that satisfied the ODE. But I am not sure if this will work all the time.
Yes,it does.
Daniel.
dextercioby said:
Yes,it does.
Daniel.
thx i thought that it did
