Art said:
Why not develop 'clean coal' power plants. The US and most other industrialised nations have massive amounts of coal available to them. Enough to last hundreds of years.
The cost of a clean coal power plant is around 25% dearer than a conventional one and the additional cost for sequestering the 750 million tons of carbon dioxide emitted each year is estimated to be around $31 million p/a.
This sounds a lot cheaper and safer than adding new nuclear power plants especially as 50% of the US electricity supply is already being produced in coal fired power plants and so the infrastructure is already in place.
"Clean coal" is a good idea (existing plants should be retrofitted immediately), but it must be remembered that it isn't completely clean, just clean
er.
There was a NOAA program a while back, its not that much. It said something to the effect that if we used all the nuclear power plants around the world, it would only last ~70? years. It would run out quite fast.
I suspect that the program assumes that we'd continue using existing obsolete designs, wouldn't use reprocessing, and economics would not make other extraction methods economical. Take away those unrealistic (wrong) assumptions, and the numbers get a lot better.
http://en.wikipedia.org/wiki/Nuclear_power#Fuel_resources
Azael said:
Isnt there huge ammounts of uranium that can be extracted from sea water??
How acurate is this claim from this page?
The basic problem is that we don't know if it'll work (by that I mean the economics in addition to the engineering) until we do it. But that just puts us in the same place as the typical alternative energy sources.
Cyrusabdollah said:
The problem with nuclear power is the waste that will stay around for 2000 years, and no place to put it.
Orefa said:
And isn't this highly optimistic? The numbers I saw were billions, not thousands. As in a billion pounds of depleted uranium with a half life of four billion years. While I'm not sure of these particular figures I have a good hunch that thinking in terms of just a few thousand years trivializes the extent of the problem.
Well, IIRC, the design criteria for the "permanent" waste site is 100,000 years. But the thing about depleted uranium is that it's depleted. It is less radioactive than the day it was dug out of the ground - that's why it has such a long half-life. In any case, we'll go into that more later...
Orefa said:
As for sea water as a source of uranium, if there is so much in the ocean already, can it be used and then returned depleted? Surely this was considered and rejected for many good reasons.
Well, if you could pump the entire ocean through it to dilute it before returning it to the ocean, sure... Otherwise you will end up concentrating it somewhere.
So the uranium is refined before use, which brings up another question. Since you need radioactivity to fuel a reactor, why discard radioactive waste instead of refining it again and re-using it? Wrong wavelength? Not technically feasible for other reasons?
The waste
can be reprocessed - it isn't reprocessed in the US for political reasons. But economics has a way of taking care of that sort of thing...
I'm showing my ignorance.
Not a problem: you are asking questions and showing a definite desire to learn.
Cyrus said:
You don't NEED radioactivity to fuel a reactor, it is a byproduct.
Um - if it isn't radioactive before going into the reactor, how does it undergo fission?
No, nuclear fuel is dug out of the ground slightly radioactive, is enriched until it is somewhat more radioactive, and after it is used, it has different mixtures of radioactive elements. But both the DU waste from the ore and the waste from the reactor can be re-processed to get more use out of it.
On this subject, there is plenty of ignorance to go around.
Orefa said:
This does not invalidate knowledge that deadly nuclear waste will have to be handled for thousands of years, which is the relevant factor.
Well, there is considerable debate about that. In my personal opinion, the 100,000 year design criteria is absurd. The spent fuel has bee sitting in local storage for quite some time, safe, secure, and not hurting anyone. In 50 years, do you know what will have happened?
Nothing. It'll still be sitting there safe, secure, and not hurting anyone. So why the requirement for 100,000 years? Nevermind the virtual impossibility of that design criteria (which is why so much money has been spent on the permanent storage idea with virtually nothing to show for it), why do we really need it?
WarrenPlatts said:
There's a question of intergenerational ethics here. Is it really fair to ask our great-great grandchildren to deal with a mess that we created?
Ironic thing to say, considering the whole global-warming mess that we aren't really dealing with (to say nothing for problem such as the national debt...)... Frankly, I think a few dozen gymnasium-sized storage sits is not a bad thing to pass down if it means eliminating fossil fuel pollution.
By then, nuclear might seem as old-fashioned as paddle-wheeled steamships seem to us. Alternatively, if our best minds can't figure out a solution now, why think that they will be able to in 100 years?
That's self-contradictory. In the first part you said that we're so smart we won't need nuclear power in the future and in the second that we're not smart enough to use nuclear power effectively. That also highlights the problem with making predictions about 100,000 year storage. What if we find another way in 50 years? Maybe we will and maybe we won't. Regardless of if
either is correct, what we
do know for sure
right now is that our spent fuel is safe
right now and global CO2 levels are rising
right now. In 50 years (about as far in advance as we can really plan), we can end up with a waste disposal situation pretty much the same as we have now and no greenhouse gas problem. Seems good to me.
In another alternate future, something superbad could happen, like world war or a mass pandemic worse than the black plague, in which case, they may not have the economic wherewithal to deal with our waste.
Certainly - but if a pandemic kills off so many people that society collapses and we can't deal with our waste... are we going to care about our waste?
The problem is building something that's going to last longer than the Egyptian pyramids, and more impervious to burglers. And where is the money going to come from? Are we setting aside a trust fund now to be used in 100 years to store nuclear waste using a method we hope they figure out because we're too stupid? If so, I haven't heard about it.
Huh? I wouldn't recommend it, but the storage facility being planned likely
will be built. With today's money. And since it will be required to be secure and not require maintenance, future money is not required.
Azael said:
as far as I can tell(Im not keeping updated on this) transmutation is very promising.
I don't know about transmutation per se (maybe...), but there are certainly reprocessing options.
The most important question is what are you suggesting as a alternative to nuclear power to replace fossile fuel?
Yes, the question requires an evaluation of the alternatives. Like I said, we can, of course, phase out nuclear power if we want to. Heck, the environmentalists were successful in getting nuclear power plant construction stopped after TMI - perhaps they will succeed in getting it phased-out (if we don't build any new plants, the old ones will need to be shut down eventually anyway). But at what cost? We've vastly increased fossil fuel energy production, and as a result, air pollution.
Cyrus said:
The problem with breeder reactors is that the waste that they make is REALLY nasty stuff.
Sure, but so what? Whether it's medium-nasty or REALLY nasty, if it's in a concrete building and not hurting anyone, what's the problem?
Because if you shoot it to space and you have to abort and blow up the spacecraft , you spray nuclear waste all over the atmosphere and kill everyone on earth.
Shooting it into space probably isn't going to happen for other reasons, but nuclear fuel has already been shot into space and it's already crashed back to earth, and if properly designed, the fuel is not released. Anyway, "spray[ing] nuclear waste all over the atmosphere and kill[ing] everyone on earth" is just not something that would be possible - even if we just shot a bunch of 55 gallon drums up there.
to be polite, I am not overestimating the dangers.
To be polite, yeah, you are. For example:
Plutonium, for example, will sit there for about 25 thousand years.
Saying how long something will sit there doesn't say anything at all about how dangerous it is. Throwing big numbers of years around is just a scare tactic (in fact - it's an ironically inverted scare tactic since the longer the half-life, the
less radioactive the material).
[some repetition of what Warren said, but I replied to posts in order. Besides, sometimes repetition helps]
