Need Help with Bioreactor Design? Check Out These Resources for Guidance
  • Thread starter Thread starter typop
    Design
Bioreactor design involves complex engineering to optimize conditions for microorganisms or cells to perform efficiently. Key environmental factors include gas flow rates, temperature, pH, and agitation, which must be closely monitored. Industrial bioreactor systems typically integrate vessels, sensors, and control systems, often utilizing programmable logic controllers (PLCs). For more targeted assistance, it's recommended to specify the bioreactor's intended use and size, as well as to explore resources from bioengineering companies. Understanding these elements can significantly enhance the design process.
typop
I have this project my supervisor wants me to carry out and I am ina dilema. I've been searching the net for how to go about it but to no avail. Please, if you have a link that might help me know how a Bioreactor is designed, could you please post it here. I will richly appreciate this.
Thanks.
NB: A bioreactor is a vessel in which is carried out a chemical process which involves organisms or biochemically active substances derived from such organisms. This process can either be aerobic or anaerobic. It is used by chemical engineers.
I am assuming that you have already seen this:
http://en.wikipedia.org/wiki/Bioreactor
Bioreactor design is quite a complex engineering task. Under optimum conditions the microorganisms or cells are able to perform their desired function with great efficiency. The bioreactor's environmental conditions like gas (i.e., air, oxygen, nitrogen, carbon dioxide) flowrates, temperature, pH and dissolved oxygen levels, and agitation speed/circulation rate need to be closely monitored and controlled.
Most industrial bioreactor manufacturers use vessels, sensors, controllers, and a control system, networked together for their bioreactor system, see programmable logic controller (PLC).
Perhaps if you get a bit more specific with what you are having problems with we can get on the right track. How big? What particular things does this design have to produce?
Like Fred said, that is a general description. The bioreactor is a fashionable name for a fermentor. You will get better results if you search for cell, virus, bacterial fermentors. Go to websites of Bioengineering, Sartorius, Bbruan and NBS etc.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
