Solve Buoyant Force Problem: Helium Balloon for Levitation - 70.1 kg Mass
To solve the buoyant force problem for a helium balloon lifting a 70.1 kg person and a 31.6 kg balloon, the correct approach involves calculating the total weight of the system, which includes the weight of the person, the balloon, and the helium. The buoyant force is determined by the difference in densities between air and helium, expressed as F(buoy) = (ρ_air - ρ_helium) * V * g. After accounting for the weight of the helium, the required volume of helium to achieve levitation is found to be 89.05 m³. This calculation corrects the initial miscalculation of 76.987 m³. Understanding the relationship between weight and buoyant force is crucial for solving such problems effectively.
kellyneedshelp
Hi, I am having some trouble with the following question:
You (mass 70.1 kg) decide to take off--literally--with a helium balloon of mass 31.6 kg. The densities of air and helium are air = 1.321 kg/m3 and helium = 0.179 kg/m3. What volume of helium is needed to levitate you and the balloon?
I think that you use the buoyant force equations, but I am not sure how. I tried doing it like this:
F(buoy)=density(fluid)*V'*g or
(101.7*9.81)=(1.321*V'*9.81) and solved for V' and got
V'=76.987 m^3
but this is not correct.
I cannot figure out how to do this problem, any help would be appreciated.
Thanks!
If we take the equation which you stated;
F_{b} = \rho V g
The 'thing' that is creating the bouyant force is the difference between the relative densities of the fluids hence in your case;
F_{b} = ( \rho_{air} - \rho_{helium} )Vg
-Hoot
First, you must state the total weight of your system:
W=W_{person}+W_{balloon}+W_{helium}
Note that your unknown volume appears in W_{helium}[/tex]<br /> Assuming that you and the balloon material contributes only negligibly to the total volume of the system, you can now find what the volume must be by equating this total weight with the buoyant force (which is the net pressure force needed to keep a volume V of air floating in..the air).
Try adding the weight of the helium in the balloon to the lefthand of your equation, the mass of the balloon probably do not include this additional weight
m_{helium}g=\rho_{helium} Vg
so the volume must be 89.05 m^3, thanks everyone!
