Show a closed subset of a compact set is also compact
filter54321
Show that if E is a closed subset of a compact set F, then E is also compact.
I'm pretty sure you refer back to the Heine-Borel theorem to do this.
"A subset of E of Rk is compact iff it is closed and bounded"
We are deal with metric spaces here. It should seem that I need to prove the same thing as in the second half of the Heine-Borel theorem. My textbook is proving Heine-Borel in a confusing way without clear statement/reason steps that I can apply to my problem.
-From the given information, E is in F
-From the given information, every open cover of F has a finite subcover of F
-From the given information, S \ E is open
...not sure where this leave me
The Heini-Borel theorem only applies to euclidean spaces. Use the definition of compact.
You don't need Heine-Borel for this. Take an open cover of E. If you add the open set S/E to that (S is the whole space, right?), then you have an open cover of F. Since F is compact... Can you continue?
I'm with you so far...you declare O and open cover of E. Then you take the union of O and S \ E and get an open set. This unified open set has to cover all E and all not-E so it has to be an open cover for all of F.
So how does the compactness of F flow back down to E? (Clearly, I have no idea what I'm doing).
Since F is compact, there is a finite subcover. So that subcover also covers E. Now you don't need the S\E set to cover E. What's left is a finite subcover of the original cover that covers E.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
