Troubleshooting PSpice Schematic: VDC=10V
  • Thread starter Thread starter david90
    Pspice Schematic
The discussion centers on troubleshooting a PSpice schematic with a VDC of 10V, a resistor, and a capacitor in series. Users are experiencing a straight line at 10V in the simulation instead of the expected curve, suggesting a potential issue with the simulation type. It's noted that a bias-point simulation may be running instead of a transient simulation, and using a step source could yield better results. Additionally, ensuring the time scale is sufficiently small is crucial for capturing the circuit's response accurately. Proper setup and configuration in PSpice are essential for obtaining the desired simulation outcomes.
david90
In my schematic, i have vdc = 10v, a resitor,ground and a capcitor. All 3 are in series except ground. When I run simulation, I get a straight line at 10v instead of a curve from 0 to 10v. I put the voltage probe between resistor and cap btw.
You're probably doing a bias-point simulation instead of a transient simulation. You might also want to try using a step source instead of VDC source.
- Warren
i'm pretty sure I'm doing a transient simulation because in the sim profile it says so.
Is it necessary to use a step source instead of vdc? On my worksheet that my teach gave me, it shows vdc.
Dc is okay , but the program may calc the initial bias point which may be the same as your final. ( skip this if you can ) . other wise use a step dc. or a switch . Make sure you time step is small enough so it makes sense . Pspice is almost always correct but the setup is usually the problem. Ray.
time scale
I think rayjohn may be on to somehting there - make sure your time scale is small enough.
For instance, if your circuit has a time constant of 10us and you simulate it for 10s, the response over the full simulation time will likely look like a steady 10V.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
