How many VDC will 120VAC support?
  • Thread starter Thread starter kubiej21
    Support
Operating six 48VDC power supplies from a single 120VAC source is feasible, but it depends on the current ratings of the 120V sockets and the fuse. The total current draw of the power supplies must not exceed the capacity of the circuit to avoid fire hazards. It's crucial to ensure that the combined load is within safe limits. Users should verify the specifications of their electrical system before proceeding. Proper safety measures are essential when dealing with high voltage and current.
kubiej21
I am looking to install 6 48VDC power supplies and I am curious as to whether or not I can operate all 6 power supplies off the same 120VAC source. I am not sure if 120VAC means that I can only operate a max of 120VDC.
It depends on the current rating of your 120V sockets as well as the fuse. If your 6 48VDC power supplies draws current anywhere near to these ratings, then you are going to have fire safety issues.
Alright, thanks.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
