Checking Average Atoms in 1 m^3 of Atmosphere at STP
The discussion revolves around calculating the average number of atoms in a 1 meter cube of atmosphere at standard temperature and pressure (STP). The initial calculation yielded 88.14 moles based on the average atomic mass of air components: nitrogen, oxygen, and argon. However, it was pointed out that nitrogen and oxygen exist as diatomic molecules, which affects the atom count. A simpler method using Avogadro's principle was suggested, emphasizing that the number of molecules in a given volume remains constant for ideal gases, allowing for calculations without needing the specific gas composition. The need to account for diatomic molecules in the final atom count was acknowledged, highlighting the importance of precision in such calculations.
mesa
So I need a check on my calculations for the average number of atoms in a 1 meter cube of atmosphere at STP.
I came up with 88.14 mols, here is how I did it:
First I calculated the average amu using percentage in air by
Nitorgen 78.08% @ 14.007 amu
Oxygen 20.95% @ 15.999 amu
Argon .93% @ 39.948 amu
I took these numbers and multiplied them by their relative percentages to get average amu for atmosphere:
10.94 + 3.35 + .37 = 14.67 amu average
We know the average density of air at STP is 1.293x10^3g/m^3
so I divided by average amu and got 88.14 mols/m^3
Is this right?
Chemistry news on Phys.org
No, that's not correct - you forgot nitrogen and oxygen are present as diatomics. But approach per se is OK.
Note that there is much simpler way. Avogadro's principle says that no matter what the gas identity is, number of molecules/atoms in a given volume is always the same (as long as gas can be treated as ideal). That means you don't need to know the mixture composition, just use PV=nRT to calculate number of moles of gas in 1 cubic meter.
I'm aware that oxygen and nitrogen exist as diatomic molecules in our atmosphere, I happen to need the number of atoms as stated in the question and title of the post but I could see how that could be missed Borek :)
That's a good approach, however I would need to recalculate for number of atoms since (as you know) the IGL counts our diatomic molecules and Ar the same so the result would be slightly less than double of n.
Either way a fairly simple check and good suggestion.
Yep, missed that, my mistake.
Borek said:
Ha ha! Since when were chemists fans of Wilder?
Pretty risque stuff for 59' but that's how he was :)
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
