Is there any relation between wavelength and brightness?
The discussion explores the relationship between wavelength, brightness, and the perception of color. Brightness is influenced by the intensity of light, which is determined by the number of photons and their energy, with blue photons having more energy than red ones. The human eye's sensitivity varies across the spectrum, making certain colors appear brighter based on context and surrounding colors. The concept of brightness is subjective and can change based on the medium used to measure it, such as digital imaging. Overall, the interplay between intensity, frequency, and human perception complicates the understanding of brightness in relation to color.
  • #101
So, now you know the relationship between power and wavelength (and frequency) and it has taken 100 posts for that to emerge. (This is no news to most people on this Forum and it's what I suggested you should find out about, way back in this thread.) Can you not see that the power in the light from an arbitrary source cannot just equate to a particular number of photons per second - because the photons all have different energies. You need to know the particular proportions of each wavelength (i.e. the spectrum) in order to work out the Power - photon rate relationship. Can you get your head round that? What wavelengths do you intend to use? Will your light source be monchromatic? That's not a very useful model to simulate. If, on the other hand, you use Power Flux, the problem (and my objection) disappears. If you're clever enough to put a bit of computer code together then this should be a piece of cake.
Btw, did you not read my bit about E = hf, about a hundred years ago on this thread?
  • #102
#59
- "Perhaps if we want to simplify or if the source emits photons of the same energy, ok? And then intensity would be directly proportional to the number of photons, wouldn't it?"
#71
- "I guarantee you that this can be done if simplify the scenario by having the light source emit photons of the same energy..."
#75
- "My other other point is if we take light source is emitting photons of the same energy, then we can convert all those definitions to use number of photons instead of energy..."
#94
If light source emits photons of the same energy, then:
1.) Radiant flux
= energy per unit time
=> number of photons per unit time True/False?
2.) Radiant intensity
= power per unit solid angle
= energy per unit time per unit solid angle
=> number of photons per unit time per unit solid angle True/False?
3.) Radiance
= power per unit solid angle per unit projected area
= energy per unit time per unit solid angle per unit projected area
=> number of photons per unit time per unit solid angle per unit projected area True/False?
4.) Irradiance
= power per unit incident area
= energy per unit time per unit incident area
=> number of photons per unit time per unit incident area True/False?
Are your blind, or something? See above.
Defined by user or imported from a database with actual measurements.
For start each light source will emits only photons of the same energy.
You wouldn't know.
Your objection is only your problem. It is necessary to quantize the light into photons because the image is quantized into pixels.
Yes, thank you. Time flies, eh?
  • #103
The pixel and the photon issue are totally separate issues. However, because you are implementing your simulation in terms of discrete quantities, you may feel pressured into the quantised way of thinking.
I can't think of many light sources of interest (certainly not cosmic ones) that are monochromatic (why not use the right word, eh?) Funnily enough, if you were to be addressing the problem of laser light, you would really be forced into using a wave approach, which would add complication.
  • #104
How else would you calculate brightness per pixel?
It's about stars and galaxies, and in actuality I guess they do not emit monochromatic light, but if it can be approximated by taking an average, or if the actual measurements are already approximated in such way, then that should be good enough for me too.
Besides, I could make light sources output any range of photons with different wavelengths in whatever proportion, if necessary. It's just a matter of how actual measurements look like, which I'm in the process of figuring out right now by looking at star databases and the way they present such information.
I thought lasers are monochromatic and that intensity of a laser is therefore directly proportional to the number of photons emitted.
  • #105
Yes. Laser light is monochromatic but it is so coherent that it can produce speckles and patterns that 'ordinary' light sources do not. It would be difficult to model (except that your beloved photons per second per sqmetre would actually apply)
You
? Well, that was my whole point. There is a 2:1 ratio of energies of the shortest and longest wavelength photons. It is hardly worth my writing all this again - it's all in earlier posts - but you will surely appreciate the difference between what you get when you count photons and what you get when you measure the energy, for different coloured stars. The accepted way of doing this will take away this problem. Star Magnitude is based on energy flow, so why not just join the club?
There is no more to be said, really. If you want your simulation to be as real as possible then why not just specify things more conventionally? As I have also said before - the actual code would be hardly any different and you would have learned something at the same time.
  • #106
It's all the same to me. If they can measure it, I can simulate it.
I only see problems and limits if I don't convert energy to individual photons.
Energy flow is based on number of photons flow.
To simulate radial spreading of light rays, to be able to model such property as is time interval between arrival of two successive photons, and so I can count photons per pixel.
Photon is more specific way to model light, energy is vague and ambiguous.
  • #107
Simulating double slit experiment is on my to do list. The goal will be to explore if there is any other, less magical, mechanics that can produce interference pattern.
  • #108
Not so: energy is a well-defined core concept in physics. Photons only risks being an incomplete model - but it is your model. Have fun.
  • #109
It's like fluid dynamics, by simulating individual molecules you can get energy, distribution, flow, pressure and what not, but not the other way around. How can photons risk to give incomplete model?
I've read somewhere that measuring distance to some distant galaxies practically boils down to counting photons, where the gap in time interval between two successive photons becomes greater the further galaxy is. How could you model that without modeling individual photons, how could you model that with energy?
  • #110
But how do they give a complete model? I think that you don't know enough about photons to make statements and inferences like that? You need to remember that the photon and wave models are complementary. Neither is 'real'. Somewhere in your head, you are visualising them like little bullets. That explains why you think they can explain everything. But they are not like bullets.
Your simulation will give 'an' answer and it will be good fun to develop. How relevant or accurate it is will depend upon how valid your assumptions are. It is important for the tail (simulation) not to try to wag the dog (actuality).
btw, what sort of simulation can deal, individually, with enough molecules to give an answer in the fluid mechanics of a turbine? I have not come across anything as complex as that. I thought that most treatments were statistical and macroscopic. IS there a reference?
  • #111
What are you referring to, interference? Is that relevant when taking photos of the stars? Can you simulate interference pattern with energy?
I think you are talking about ME, again, it's off topic and unnecessary. What are you doing here, what is this to you, some vanity contest? Ok, I know more about photons than you or anyone else, how about that?
And? You forgot to mention what is your point. The result of the simulation is an IMAGE. That is what defines how the simulation should be handled. When you shoot individual photons they produce discrete individual 'dots' when they hit a detector, and that's what is important here. It's as real as you can get.
There are no assumptions, relation between compound energy of some amount of light and the number of photons is defined by the energy of individual photons. The result will be valid and accurate as much as actual measurement are.
a.) can you simulate radial spreading of light rays with energy?
b.) can you simulate time interval between arrival of two successive photons with energy?
I could make such program, it would just take a long time to compute. Fortunately however photons are much easier to simulate as they do not interact with each other, not in the way that would be relevant for this simulation anyway. -- Don't you have anything better to do? Why do you even care? Did photons kill your dog when you were kid, or something, why do you hate them so much?
  • #112
How can you ask whether interference (diffraction?) is relevant when observing the stars. What Astronomer can ignore diffraction? Why do they all want bigger telescopes? What do you think the Airy Disc is all about? Are you aware that the diameter of the Airy disc varies with wavelength? You are seriously trivialising the Physics involved in the system you are claiming to simulate. It is making a pretty big assumption that a given photon will hit a given pixel - that's what diffraction is all about. Does your simulation do more than to take a basic ray model and then assume that photons are traveling along these rays?
I think you could find writing a valid simulation of fluid molecules could be harder than you think.
