3 Phase VSC SPWM (Triple-n harmonics)
Triple-n harmonics are accepted in the output voltage spectrum of Voltage Source Converters (VSCs) using Sinusoidal Pulse Width Modulation (SPWM) because they naturally cancel out in three-phase systems. This cancellation occurs due to the symmetrical nature of the three-phase current, where harmonics that are integer multiples of three do not contribute to the line-to-line voltage. The discussion clarifies that "triple-n" refers to harmonics that are multiples of three. Understanding these concepts is crucial for optimizing VSC performance in applications. The cancellation of these harmonics helps improve overall system efficiency and reduces distortion.
jegues
Why is it that we accept triple-n harmonics in the output voltage spectrum of VSCs?
Assume we are using SPWM where the frequency modulation index is selected to be a large odd integer multiple of 3.
Thanks again!
Sorry I don't understand the acronyms.
In case this is three-phase current, triple-n harmonics cancel out naturally.
Sorry about the acronyms, I thought they were commonly used.
VSC = Voltage Source Converter
SPWM = Sinusoidal Pulse Width Modulation
Can you explain further how the triple-n harmonics cancel out naturally? And by "triple-n" do they just mean the harmonics that are integer multiple of 3?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
