Time Delays Across Saddles: Probing Modified Gravity in the Solar System
  • Thread starter Thread starter wolram
    Graviity
Modified gravity theories suggest that strong signals can occur near the saddles of the total gravitational potential in the solar system, leading to diverging time delays for echoes. These models propose that gravity may exhibit infrared divergence or confinement, making them challenging to disprove. Lunar Laser Ranging during an eclipse could effectively measure these time delays, potentially validating or refuting these theories. Additionally, Very Large Baseline Interferometry could investigate delays across the Jupiter-Sun saddle. Such research aims to enhance understanding of gravity's infrared behavior and the existence of hidden strong gravity regions or singularities within the solar system.
wolram
Dearly Missed
arXiv:1212.3687 (cross-list from gr-qc) [pdf, ps, other]
Time delays across saddles as a test of modified gravity
Joao Magueijo, Ali Mozaffari
Subjects: General Relativity and Quantum Cosmology (gr-qc); Cosmology and Extragalactic Astrophysics (astro-ph.CO); Earth and Planetary Astrophysics (astro-ph.EP)
Modified gravity theories can produce strong signals in the vicinity of the saddles of the total gravitational potential. In a sub-class of these models this translates into diverging time-delays for echoes crossing the saddles. Such models arise from the possibility that gravity might be infrared divergent or confined, and if suitably designed they are very difficult to rule out. We show that Lunar Laser Ranging during an eclipse could probe the time-delay effect within meters of the saddle, thereby proving or excluding these models. Very Large Baseline Interferometry, instead, could target delays across the Jupiter-Sun saddle. Such experiments would shed light on the infrared behaviour of gravity and examine the puzzling possibility that there might be well-hidden regions of strong gravity and even singularities inside the solar system.
Its the first i have heard about about strong regions of gravity in our solar system, have i been missinng the properties of some modified theories
Space news on Phys.org
By "saddle region" are they referring to the point close to the planet where its gravity begins to overwhelm the Sun's?
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
