Electromagnetic motor using battery and magnet?
The discussion centers on the mechanics of an electromagnetic motor that utilizes both a battery and magnets. Participants question the validity of the motor's operation, considering whether it is a legitimate concept or a hoax. The role of Ampere's force is debated, with some suggesting it may not apply in this context. The configuration of the current flow and magnetic field is analyzed, particularly how a perpendicular orientation can generate torque. Overall, the conversation seeks to clarify the principles behind the motor's functionality.
2sin54
I've been wondering how does this motor work (if it is not hoax in the first place)
I was thinking about Ampere's force but apparently it doesn't really have an affect here. Any ideas?
You have a radial current flow (moving charges) and a magnetic field perpendicular to that.
How can the magnetic field be perpendicular to the current flow?
As far as I can see, the magnetic field is vertical (or at least it has a vertical component), while current flow is horizontal. In particular, the radial component of the current flow in the vertical component of the magnetic field will give a torque.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
