What Components Are Best for Designing a Lithium-Ion Charging Circuit?
  • Thread starter Thread starter tehcabbage
    Charging Circuit
The discussion focuses on designing a lithium-ion charging circuit that outputs 3.3V and is rechargeable via a USB power supply. Key components mentioned include the LM3622M-8.2 charge controller, an eForCity 2000 mAh battery, and a TPS54316 voltage regulator. Participants emphasize the importance of following the application sheet for the LM3622 to ensure safe charging practices, given the potential dangers of lithium-ion batteries. There are inquiries about the adequacy of the chosen components and suggestions for alternative designs. Overall, the circuit design appears feasible if proper guidelines are adhered to.
tehcabbage
Hello everyone! First post, so I apologize if I am in the wrong area.
I am designing a charging circuit for a project, but I don't have much experience with power electronics. The circuit must output 3.3V and be rechargeable through the use of a USB power supply (5V DC). Here is what I am currently thinking:
I'm looking into an LM3622M-8.2 lithium-ion charge controller, an eForCity 2000 mAh battery, and a TPS54316 voltage regulator.
My current plan is to have the voltage from the USB going straight into the LM3622, which will regulate the voltage and current being applied to the battery. It looks like the LM3622 will do most of the regulation for me, but I was wondering what else I might need to do. The battery will push 3.7V to the TPS54316, which is step down the voltage to 3.3V before it is sent to the rest of the circuit.
So my main questions are:
- What do I need to do with the LM3622?
- Is there a better component for lithium-ion voltage regulation?
- Is there a better way to design a lithium-ion charging circuit?
- Am I missing something big?
- Does this seem like it will work?
Hi...
Just a quick word. Best of luck with your project.
I hope I don't have to tell you that Lithium-Ion batteries can be unforgiving if not downright dangerous if charged incorrectly.
Malc
I'd second that advice. If you stick to what the application sheet for that controller tells you then you should be OK. They will certainly tell you about any obvious dangers involved with charging Li batteries.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
