Eliminating Elements in Commercial FEA Solvers
Elements are eliminated in commercial FEA solvers based on criteria like stress or strain, particularly in scenarios involving destructive impacts, such as ball impacts on steel plates. This elimination represents material that can no longer transmit loads due to excessive deformation or damage. While this approach simplifies the model, it raises concerns about the accuracy of results, as the eliminated elements effectively become null. The context of analysis, such as explicit impact analysis, is crucial in understanding the implications of element elimination. Overall, the method aims to accurately simulate material behavior under extreme conditions while balancing model complexity.
pukb
I want to why actually elements are eliminated in commercial fea solvers.
There is a criterion like stress or strain at which elements having acheived that state are eliminated.
Wouldnt it lead to wrong results because, the material at eliminated elements place has become null.
What type of analysis are you talking about here?
"Eliminating elements" could mean different things in different contexts.
I was trying to understand ball impact on a steel plate. So we can take it as explicit, impact analysis.
I am talking about elimination of elements of plate on impact of the ball.
The only context I can think of where elements are "eliminated" in an explicit FEA solve would be in an explosion or destructive impact event where material is being destroyed.
"Destroyed" isn't quite the right word, but if the material in an element is deformed or damaged so much that it can no longer transmit any loads (e.g. the compressive stress exceeds the crushing strength of the material) deleting the element from the model is a simple way to represent that behaviour.
As you said AlephZero, it all depends on what he means by "eliminating elements."
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
