Why is chlorine the central atom in a chlorate ion
  • Thread starter Thread starter Coco12
    Atom Ion
In the discussion about the Lewis structure of chlorate, it is clarified that chlorine is the central atom, despite the common guideline that the central atom has the fewest valence electrons. The reasoning provided emphasizes that chlorine, a Group 7 element, is less electronegative than oxygen, which typically makes it the central atom in compounds where it is bonded to multiple oxygen atoms. The conversation also notes that while this trend generally holds true, there are exceptions, particularly in cases involving metal ions and certain organophosphorus compounds. Ultimately, the positioning of chlorine in the center is attributed to the equivalence of the surrounding oxygen atoms rather than solely its valence electron count.
Coco12
I know that when you draw the lewis structure for chlorate, the chlorine goes in the center with the oxygen bonded to it. What I don't understand is that the teacher told me that the central atom is the element with the fewest valence electrons. So wouldn't that make oxygen the central atom?
This is what I think:
Is it because the Group 7 elements are the most electronegative so when given a compound where there is 1 of the Group 7 element and 2 or more of elements in the other groups, then the Group 7 element will always be central?
Chemistry news on Phys.org
Try posting your question in the HW/Cousework section. You may get better results there.
In most cases, the central atom will have a lower electronegativity than the ligands.
This is true with metal ions, which have less valence electrons than typical ligands like oxygen etc, but it is also true for chlorine as electronegativity decreases down one column in the periodic system. Nevertheless there are exceptions also to this rule, e.g. in organophosphorus componds where some alkyl function acts as a ligand.
So the reason why chlorine is the central atom is because it has a lower electronegativity than oxygen?
I wouldn't say that's the reason as such, more that it's been shown that all the oxygens are equivalent, and for that to be the case, the chlorine has to be in the middle. Whether this is at the right level of answer may depend on the level of the question.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
