Metric for rating funtion accuracy from R^m to R.
The discussion focuses on finding a metric to evaluate the accuracy of functions mapping from R^m to R, specifically for a program generating pseudo-random expressions. The user seeks methods to compare expected outputs against actual outputs, with a preference for metrics that yield a single real number. The sum of squared errors is mentioned as a common method, but the user opts for the sum of absolute errors to avoid underestimating the performance of poor solutions due to the randomness of the generated functions. There is some confusion regarding the nature of the data, particularly whether it contains significant noise. Overall, the conversation revolves around selecting an appropriate accuracy metric for function evaluation.
TylerH
I'm writing program in which I generate pseudo random expressions with the hope of finding one that closely approximates the given data set. The functions map from R^m (an m-tuple of reals) to a real. What I need is a way to rate the functions by their accuracy. Are there any known methods for doing this? Maybe something from stats.
Ideally this would be a method that would take a list of expected outputs and actual outputs and return a real number. A uniform distribution would be good, but not required.
Mathematics news on Phys.org
A standard thing is to do something like
\sum_{j} \left( y_j - z_j \right)^2
where the yj are the actual data that you measured, and the zj are the predictions that you made (this is called the sum of squared errors). It's used mostly because it's easy to work with sums of squares when doing analytical calculations (like trying to minimize it). If you're doing a numerical method, people will often instead use the sum of the absolute values of the errors, especially if they consider the property "makes sure there are no significant outliers at the cost of being off by slightly more on average" to be a negative quality
I went with the abs value one because, by nature of the fact they're all random, there are going to be a lot of bad solutions. So I thought a metric which doesn't underestimate their badness would be better. Thanks.
I don't really understand what this post is trying to get at... do you mean that your data has a lot of noise in it?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
