Cathodes/Anodes in Chemistry and Physics
  • Thread starter Thread starter quanticism
    Chemistry Physics
Cathodes are defined as electrodes where conventional current flows out, while anodes are where it flows in, leading to confusion between chemistry and physics. In galvanic cells, the labels align with these definitions, but in vacuum tubes, the behavior of electrons complicates this understanding. Inside a cathode ray tube (CRT), electrons move from the cathode to the anode, while outside, conventional current flows from the anode to the cathode. This distinction highlights the difference between conventional current (positive to negative) and electron flow (negative to positive). Understanding these concepts clarifies the roles of cathodes and anodes in different contexts.
quanticism
Hi,
I'm confused at why cathodes are the positive terminal in chemistry but appear to be the negative terminal in physics. I hope someone can clear this up for me.
Definitions:
Anode: An anode is an electrode through which conventional current flows into a polarized electrical device.
Cathode: A cathode is an electrode through which conventional current flows out of a polarized electrical device
Galvanic Cell
Vacuum Tube
cathode-rays-formation.jpe
Going by the definition above, I agree with the galvanic cell "cathode/anode" labels.
However, looking at the vacuum tube, the electrons traveling to the right through the partial vacuum and entering the anode, ie conventional current is leaving the anode which seems to contradict the provided definition.
Likes davidbenari
The definitions describe what happens outside the device.
Inside the CRT, electrons travel from the cathode to the anode.
Outside the CRT, to complete the circuit, electrons travel from the anode to the cathode.
So outside the CRT, conventional current travels from the cathode to the anode.
So conventional current flows from outside the CRT into the anode.
Likes davidbenari
Thank you very much! I finally see the light now :)
There is a difference between conventional current (taken as flowing from positive to negative) and electron current. This link will explain it and the history of the convention. http://web.engr.oregonstate.edu/~traylor/ece112/lectures/elect_flow_vs_conv_I.pdf
The electrons are reppeled from Cathode and attracted to Anode.
The electrons in galvanic cell can not move trough the Porous disk, and they move trough the outside circuit.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
