Thermal White Noise - Johnson–Nyquist noise
The discussion centers on measuring thermal white noise generated by chemical batteries, specifically focusing on the complexities of calculating frequency from noise measurements. Participants emphasize that classical thermodynamic formulas for thermal noise suggest power spectral density is independent of frequency, but quantum effects must be considered at high frequencies. There is contention over the appropriate equations to use, with some arguing that the original poster is using the wrong formula that incorporates Planck's constant. The conversation also touches on the distinction between noise measured in Kelvin and frequency in Hertz, clarifying that thermal noise can indeed be associated with specific frequency ranges due to heat generation in batteries. Ultimately, accurate measurement and understanding of the equations involved are crucial for resolving the complexities of thermal noise in this context.
Mechatron
I'm trying to measure the thermal white noise generated by chemical batteries.
So far I've measured the current noise, the voltage noise (V noise) and the bandwidth (delta v).
From the equation below, I'm trying to solve the equation for the frequency.
The problem is that there's an exponential expression in it. But it gets worse, the frequency f is in it.
http://s24.postimg.org/jbunj5z1h/Vnoise.jpg
All I could come up with is to put hf/kt on one side of the equation and I'm stuck with ln (4hfr delta v / V^2). Do you have a solution?
Looks like you are using the wrong formula for you situation.
The formulas for thermal noise that we typically use in EE are derived from classical thermodynamics which leads to power spectral density being independent of frequency. Of course this implies that there is an infinite amount of thermal noise power in every resistor when we include all frequencies up to infinity (look up "ultraviolet catastrophe").
The resolution to this paradox (thanks to Planck) is that when frequencies get very high, classical thermodynamics breaks down because the quantization of energy (E=hv) becomes significant.
Your formula is a general formula that includes quantum effects, and thus shows a dependency on frequency.
I think you are wrong. The equation calculates the frequency with respect to (1) the current running through an internal resistance, and (2) the bandwidth of the white noise. What you end up with is simply a complex frequency, which is solved using the Lambert W equation. Might as well throw in the towel and call it a simple frequency.
And by the way, for the record, Johnson–Nyquist noise is classical thermodynamics.
You can not, I repeat, you can not exclude the frequency when calculating white noise. You don't know noise is measured in Hertz?
Mechatron said:
You can not, I repeat, YOU CAN NOT exclude the frequency when calculating white noise. Have you lost your mind? You don't know noise is measured in Hertz?
noise ( thermal) is measured in K ( Kelvin) frequency is measured in Hz ( Hertz )
Dave
Color me confused. How is noise measured in Hertz?
I thought noise was expressed in power or voltage or current. The amount of power may depend on the bandwidth ( so noise voltage is sometime expressed as volts/root-hertz, etc)
At very high frequencies you can determine the power spectral density by using hf. Do a unit analysis of hf and you get volts, or eV.
uh huh
when I am dealing with thermal noise in low noise RF preamplifiers etc its always measured in KD
Yes, in his paper Nyquist used classical thermodynamic arguments including the classical equipartition law (along with transmission line theory) to derive
<br /> v_n^2 = 4 R k_B T \delta \nu<br />
in order to explain the experimental results published by Johnson. This is the classical result. Notice that it is not the equation you posted. Yours has Planck's constant in it, which does not show up in classical physics. Nyquist does state the equation you use at the end of his paper to indicate what happens at very high frequencies and/or low temperatures, when the classical equipartition law no longer holds and quantum effects must be included. Of course the classical result is all that was needed to explain Johnson's data. If you take the limit as h \rightarrow 0 (or equivalently assume h f &lt;&lt; k_B T) in your expression then you recover the classical result.
May I ask how you are doing this measurement? Are you really in a regime where it is not true that h f &lt;&lt; k_B T? What is the bandwidth of your measurement? etc. If you really want help (as opposed to simply looking to "in your face" people) then we need more information. For example, usually we know f and \delta \nu from the measurement setup, so it isn't clear why you want to solve for f at all ...jason
Likes 1 person
davenn said:
uh huh
D
I don't doubt it, but technically speaking I think you are referring to Noise Temperature, which of course has units of temperature. We do similar things at my workplace, where we might say, "that amp has 2 dB of noise" when we are actually referring to the noise figure. In any case, the noise performance of amps is one step beyond the noise from a resistor, which I think is all the OP is concerned with.
jason
I am speaking about the frequency disturbances caused by thermal radiation. As far as I understand, the frequency generated from current passing the internal resistor in a battery can be found in the unit for frequency in the equation in the link below:
http://s24.postimg.org/4cqk2wbet/Vnoise.jpg
Thank you for your reply. I will be as clear as I possible can.
Please go to the following website regarding 1995 IEEE international frequency control symposium:
http://tf.nist.gov/general/pdf/1133.pdf
In general, it is accepted that a common DC battery only supplies a DC voltage.
However, a small frequency somewhere arround 20 - 1000 Hz is generated, due to heat generated in the battery. I call it thermal noise, forget I ever said white noise. You can calculate the current noise with the instrument shown on page 370 (page 4 in the pdf). You can then use the current noise to calculate the voltage noise. Subsequently you use the voltage noise and the measured temperature of the battery, which would be between 300 - 323 Kelvin, to find the bandwidth of the frequency/noise. Finally, you can add this data into the equation in the link below, as shown on page 1:
But you see, there's a problem, you've got exp / e in the equation. By simplifying the equation, you can get y = ln (x*y -1) / w. You can solve this equation with respect to y, which represents the frequency. You end up with an expression including a product log:
http://www.wolframalpha.com/input/?i=y/w+=+ln((x*y)-1)+with+respect+to+y
But the problem doesn't stop here. Now you're stuck with a complex number.
But really, this is a representation of a complex frequency.
Concept of complex FrequencyDefinition: A type of frequency that depends on two parameters ; one is the ” σ” which controls the magnitude of the signal and the other is “w”, which controls the rotation of the signal ; is known as “complex frequency”.
Makes sense, right? A complex number is just a two dimensional number:
http://m.eet.com/media/1068017/lyons_pt2_3.gif
So I think I just need to know, is the frequency in the equation, the frequency which you'd see on an oscillator, generated from the heat from the battery?
Michael
You are using the wrong equation.
You are using equation (1) of the NIST document.
You should be using equation (2) "At low frequencies Johnson noise can be approximated by...", which is the same equation that jasonRF has posted.
You are dealing with kHz right, not GHz or THz.
I read the paper. The noise is essentially white except for the lowest frequencies, as indicated by their data and by their statements. They do not calculate the bandwidth from the voltage noise and the temp; instead, the resolution of their spectrum analyzer defines the bandwidth. In fact, "measurement bandwidth" is always what the bandwidth number in Nyquists formula means. This is even stated in the beginning of the paper you link. Note that their voltage noise measurements are presented in spectral density = Volts / sqrt(Hz). To place their measurements in this form they had to know the bandwidth already (after all, they set up the spectrum analyzer, right?).
You are still mistaken - that equation describes the frequency dependence of thermal noise. Noise is generated at all frequencies! In any case, for parameters relevant to your case: T = 300K and f = 1000 Hz,
<br /> \frac{h f}{k_B T} \approx 10^{-10}<br />
so surely the classical result is all that matters. Just look at the data in the paper. It is flat with frequency except at the lowest frequencies where other processes are dominating. It is not frequency dependent (edit: it is not frequency depended in the portion of frequency space you seem to care about).
jason
jason
Exactly, the equation describes the frequency dependence of thermal noise.
The noise you put in the equation is a specific one. The frequency I want to calculate using the equation, is the same frequency I measure using an oscilloscope. Please stop saying it's not frequency dependent when the frequency is in the equation, and the frequency is what I want to calculate. In other words, it's a DC voltage signal I'm looking for, with oscillations.
I've added a graph:
http://s22.postimg.org/hp31y8dnl/Graph.png
Here's why it's so important to me:
http://www.acs.psu.edu/drussell/Demos/superposition/pulses.gif
The small wave represents the wave/frequency generated from heat from the battery, and the larger wave is the desired wave which I generate in a circuit. The DC voltage with oscillations is introduced into the circuit, and I believe with a feedback/loop, thing's just get worse.
Mechatron,
For the third time...you are using the wrong forumla. Use equation (2) in NIST document, not equation (1).
We don't need to invoke Planck's constant when working with signals in the kHz range.
jason
"They do not calculate the bandwidth from the voltage noise and the temp".
I think you need to read the paper again. They calculate the Voltage noise with an equation which consists of the bandwidth and the temperature. You can rearrange this equation and solve it with respect to frequency. Please look at the following image in the link below!
http://s30.postimg.org/c86jz3fkh/frequency.png
This frequency F, is this the frequency I would see on an oscillator? Is this the frequency generated from heat from the generator?
the_emi_guy said:
Mechatron,
I think I understand what you're trying to say, but you don't want me to use the equation 1, just because an approximation would be good enough, which would exclude a very important data.
the_emi_guy said:
Mechatron,
Which Boltzmann's constant is being used? Is it 8.617 3324×10−5 eV/K?
I am encouraging you to employ equation (2) because you will avoid the problems you struggling with dealing with the exponential and the frequency term. At kHz frequencies you are not losing any significant accuracy by avoiding the use of quantum mechanics. Kind of like ignoring general relativity and sticking to Newton's laws to calculate the flight of a cannon ball.
Stick with the SI units for Boltzmann constant (JK^-1) since all other electrical quantities volts, amps etc. are SI.
jason
You said it's not frequency dependant, but in equation 2, bandwidth is included.
Is there any way of calculating what the frequency is based on the bandwidth of the signal?
I've added a graph:
Is this what you are measuring on your oscilloscope? If so, what exactly is the circuit you are measuring? Is there a very narrowband filter in there somewhere (either in the circuit or in the way you setup your measurement device)? If not, then the oscillation you see isn't from Nyquist thermal noise (it could be from something else, just not Nyquist thermal noise).
You should try plotting the function you are using from 10 Hz up to 10 MHz for T=300K. It should look quite flat. In fact, it will look flat until your frequency gets close to k_B T / h which is the order of 10^{13} Hz if I did the arithmetic correctly.
EDIT: Listen the_emi_guy and use consistent units. Actually, listen to him on everything - he is steering you the right way every time as far as I can tell.
jason
Equation (2) only requires bandwidth, not frequency. The idea is that the spectral noise density is flat. There is the same amount of noise power in the 1KHz-2KHz bandwidth as there is in the 10KHz-11KHz bandwidth.
Of course we are only talking about thermal noise. At low frequencies other noise mechanisms become very significant (1/f noise in particular).
Likes 1 person
Thread closed for Moderation and cleanup...
Thread re-opened.
Thermal Noise in batteries - Signal to Noise
I am building a transmitter which will generate a 20 kHz signal from a DC voltage supply (battery).
The battery is generating thermal noise which will interfere with the signal. The thermal noise is generating an electrical signal (alternating current) which can be measured in Hz, as far as I'm concerned. I expect this AC signal to be anywhere between 20 - 1000 Hz. Below I am giving you a more technical definition of the terms that concern me.
Thermal noise is approximately white, meaning that its power spectral density is nearly equal throughout the frequency spectrum. The amplitude of the signal has very nearly a Gaussian probability density function.
A noise signal is typically considered as a linear addition to a useful information signal. Typical signal quality measures involving noise are signal-to-noise ratio.
Signal-to-noise ratio is defined as the power ratio between a signal (meaningful information) and the background noise (unwanted signal).
I want to know what the linear addition to the 20 kHz signal would be.
If I were able to calculate the signal-to-noise ratio, how can I use it to calculate this linear addition? Can Voltage Noise (dBV/Hz) be used to find the linear addition? How can I calculate the linear addition?
I've added a link to a pdf file regarding 1995 IEEE International Frequency Control Symposium.
Using Planck's law does not seem useful to me, because I end up with a very high value.
If the frequency is low enough:
f = KbT/h = =1.3806488*10^-23 J/K * 300 K / =6.62606957*10^-34 Js = 6.2 THz (Tera Hz).
So I think this frequency is not the same as the "linear addition".
Reference to Planck's law:
http://en.wikipedia.org/wiki/Johnson–Nyquist_noise
Final words:
I am interpreting thermal noise as the linear addition to the desired signal in this manner;
Frequency disturbance from thermal noise + signal = 20Hz + 20 000 Hz = 20 020Hz.
The purpose is to find a suitable filter capacitor which can remove the thermal noise / linear addition. I know it might seem unnecessary, but it's for respect to science research purpose, but also because I want to build more sensitive systems. I just want things to be perfect.
This is where you are getting off track, noise does not add in the manner you are describing.
We need to know the *bandwidth* of the 20KHz signal, or more specifically, the bandwidth of the receiver that will be trying to recover this signal. I'll explain why shortly.
Here you are saying that the thermal noise is both white and limited to the very small 20-1000Hz band. These are mutually exclusive statements. White means its power spectral density at 1MHz is the same as at 20Hz.
So let's say that the power spectral density is 1nW per Hz of bandwidth. This means that there will be 1nW of noise power in every 1Hz of bandwidth. If I build a perfect (doesn't create any noise of its own) receiver that tunes to 20KHz with a bandwidth of 1Hz (receives everything between 20,000Hz and 20,001Hz, rejects everything else) then I will have 1nW of noise power coming out of this receiver.
On the other hand, let's say your receiver has 1KHz of bandwidth (20KHz - 21KHz received) then we will have 1000*1nW = 1uW of noise power received.
If your 20KHz signal is 1W, then our SNR is 1W/1uW.
Hope this clarifies things, we need to know the bandwidth of the 20KHz receiver, and the noise power in whatever units (dBm/Hz, nW/Hz).
Likes 1 person
Is this as simple as:
1. At moderate frequencies the noise is not frequency dependent.
2. At all frequencies the measured noise power is bandwidth dependent.
Even though both the frequency and bandwidth are expressed in Hz., they are completely independent.
Please be aware that I am not taking the receiver into consideration. We need to focus on the transmitter only. It's the signal transmission that matters, not the reception.
So you're saying that heat generated from a battery does not output an alternating current in a circuit? The transmitter generates a square wave, so it has infinite bandwidth. However, the oscillator indicated that the transmitter wasn't generating a perfect 20 kHz signal, you could see some oscillations on top of the square wave, and the oscillator indicated it was swinging between 20 000 - 20400 Hz. I understand now the relationship between noise power and bandwidth.
But I need to know how the heat generated from the battery, will change the 20 kHz signal, or better yet, how it affects a DC signal alone. Just take a good look in the pdf file again. I could use equation 2 to find the bandwidth of the thermal noise from the battery. Just forget about the bandwidth of the receiver, it's not needed. Because no battery can produce a perfect DC voltage due to heat, which is but not limited to its internal resistance.
From the first sentence in the link below:
"In electronics, noise is a random fluctuation in an electrical signal"
http://en.wikipedia.org/wiki/Noise_(electronics)
This electric signal is produced by thermal noise, and is added to the 20 kHz. I'm not measuring this thermal noise in volts, but in Hz in the oscillator. They are added just like illustrated in the link below (from a mathematical perspective, physically they travel the same way):
  • #31
I'm sorry if things seem to be off track, but I think we're close to solving our problem.
I wanted to add that I calculated the bandwidth using the second equation in the pdf with value; 300 K, (r+R) 1000,2 Ohm, -204dBV/Hz and the Boltzmann's constant of 1,38*10^-3 which gave me a bandwidth of 2,51 *10^21 (Zetta Hz), which in the electromagnetic specter would be gamma radiation (if it was a frequency), which doesn't seem very reasonable to me. And as previously mentioned, the f=KbK/h of 6,2 THz didn't make much sense either. So I'm really, really confused.
  • #32
Have you even considered that the variations in the osc freq is due to phase noise being generated by the oscillator and has nothing to do with the battery at all ?
cheers
Dave
  • #33
Closed pending moderation.
  • #34
Thanks Evo! Thread re-opened after merging two threads on the same subject.
  • #35
@Mechatron -- it sounds like the ringing or noise you are seeing is caused by something else. Batteries are not noisy. You can always follow the battery with a low-dropout linear voltage regulator to be extra sure that your power supply is quiet.
  • #36
Glad you could join berkeman. I can't wait to hear from the_emi_guy again. We're getting close to solve this mysterious problem. It is very clearly stated in the 1995 IEEE International Frequency Control Symposium that batteries generate thermal noise. It's very small, but it matters. Phototransistors are also noisy when they get hot. That is why we add heatsinks to them, to cool them off. But disturbances from voltage supplies can be filtered through a filter capacitor, which acts as a high pass filter. It seems logic to me, to use the signal-to-noise approach. I'll get back to this in the morning and hopefully the_emi_guy will reply soon.
  • #37
Adding a bypass capacitor is a good idea, and in combination with a series resistor that forms a low-pass filter, not a high-pass filter.
What do you think about adding a low-dropout linear voltage regulator? that may be your best bet. What level of noise voltage are you shooting for? Are you making uV level measurements? It's hard to believe that the battery noise is creating an issue in a radio transmitted waveform... :smile:
  • #38
Of course batteries generate white noise, everything with a resistance does. But since the noise is white it does not have a specific "frequency"; the noise contains ALL frequencies within the BW of you measurement; all you see on an oscilloscope is a wide "band", not e.g. a sinewave or any form of pattern If you look at a spectrum analyzer all you see it a flat line. If your noise has "structure", it is either interference or noise with a non-white spectrum (flicker noise, random walk etc).
Hence, whereas the white noise might make the signal from your transmiter slight wider (althought this effect is nearly always extremely tiny compared to other sources of noise) it won't really distort the shape of you signal (unless there are other non-linear effects involved).
The point is, it is extremely unlikely that the noise from the battery is the source of your problem.
I occasionlly do measurement where we both generate and measure frequencies with rather high accuracy (albeit in the GHz range); white noise is almost never a problem as such (unless you count the noise tempeature of the amplifiers), you are mostly fighting with non-white noise (1/f noise in the electronics) and -more importantly- systematic noise from badly filtered power supplies etc.
  • #39
A battery can reach temperatures of over 120 Fahrenheit (322 Kelvin). The more current that passes through your circuit, the hotter your battery gets. When you need to power a machine consistently, things can get pretty hot, and this would generate significant thermal noise, which would be very bad for a very sensitive transmitter circuit. Why do I care so much about such low frequencies? Because I want a receiver to focus on a specific signal, so the bandwidth of the bandpass filter will be very small, so the transmitter must generate a very clean signal. So I have to compensate for white noise generated from light, such as generated from 60 Hz lamps and thermal noise from electronic components. I would not go for the voltage regulator, as the voltage regulator would consume more current. And it speaks for itself, it's a voltage regulator. But it's a frequency regulator I need. I'd rather use a rectifier diode. But a filter capacitor does just that, rectifies the DC voltage. A DC battery is actually 99% DC and a fraction AC mixed.
  • #40
  • #41
In order to answer that you need the BW of your 20 kHz signal plus information of how any noise couples into it. If you assume that the noise voltage is simply added to your signal (which is pretty unlikely given that there must be other components in the circuit go generate the 20 kHz in the first place) you can just calculate the noise per root Hz, multiply by the the BW and then calculate the RMS voltage noise that will be added to our signal. If that voltage is much smaller than the signal amplitude you can eliminate Johnson noise from the battery as being a significant source of noise.
This is all pretty much standard stuff, and several of the people who have already replied in this thread has experience with this (I am one of them).
When we say that the battery is unlikely to be the source of your noise, we are speaking from experience.
  • #42
I can calculate the noise per root Hz, you mean V/sqrt(Hz)? And if I multiply that with Hz, I get VHz/sqrt(Hz). Can you please illustrate this calculation with a mathematical expression?
But the RMS noise voltage is in volts. But the noise that will be added to my signal should be in Hz.
  • #43
Look at the diagram in the link below:
http://s13.postimg.org/m6bl81wtz/snr.png
I need that noise in Hz, not dbV/Hz. I can't see how calculating the RMS voltage noise that will be added to my signal is in Hz. I like the steps you provided, I want to use this method, but the final value must be in Hz.
  • #44
OK, now I see what you are trying to do.
In order to do this calculation you need more information. The book you are referring to (which I believe I have somewhere) is talking about Johnson noise affecting the feedback signal in the electronics in the oscillator loops.
In a typical "simple" circuit you would have are reference resonator and then feedback electronics creating a loop which oscillates at some frequency (set by the resonator). Now, since the feedback signal is just a voltage any type of noise will interfer it, meaning the output frequency becomes noisy.
Hence, in this situation the voltage noise is "translated" to frequency noise(or phase noise).
However, how this happens depends on the details of the circuit, there is no general answer and iit can become quite complicated, especially if there are non-linear processes involved (which is often the case at RF frequencies). In any real life situation you would probably use SPICE etc to do the calculation.
Moreover, a properly designed circuit will be more of less insensitive to things like noise in the batteries: the white noise you see when measure an high frequency oscillator is typically dominated by the noise temperature of the feedback amplifier. That said, for frequencies as low as 20 kHz most of the "problematic" noise will probably be 1/f noise from both the amplfier and the rest of the electronics (white noise is rarely a real problem since it averages out over long times).
If you want to read more about this I would recommend Enrico Rubiola's book on phase- and frequency noise in oscillators. Enrico is THE guy when it comes to stuff like this.
You can also find plenty of free information on his website
http://rubiola.org/index.html
Likes 1 person
  • #45
Mechatron,
Can you confirm f95toli's idea that you are concerned about how thermal noise translates to phase noise on your 20KHz clock? If so, be aware that phase noise is measured in time units (ps, UI etc), not Hz.
There is a procedure for doing this but this kind of analysis is used on clocks that are in the hundreds of MHz and GHz. I really doubt that it would make any sense to apply it to a 20KHz signal.
Sounds like you have a 20KHz clock and it does not look clean on your scope?
Maybe you should just send us a screenshot of your actual signal, you may just have a signal integrity issue.
  • #46
I did mention osc phase noise many posts ago but it was ignored
Dave
  • #47
Dave
You're right, you may have nailed it on post #32. He may be dealing with a frequency stability or drift issue.
  • #48
How about a circuit diagram or block diagram of exactly what is being done, what frequencies are involved, and roughly how the battery noise affects (gets transformed into something that affects) the final performance?
  • #49
That was really useful. I agree that it is rather pink noise than white noise. I agree the noise contain all frequencies within any given bandwidth. But I've been given instructions on how to calculate signal-to-noise ratio by you guys. If only you instructed me how to use this to calculate the distortion of the signal in Hz, that would be great. These little spikes must have some frequency of them selves. Anyway, I do want to calculate this phase noise.
Would you please tell me how I can find the phase noise of a linear process? Taking only the battery and its internal resistance into consideration?
  • #50
Then I'd have to sue my self for copyright infringement. Since phase noise is measured in dBc/Hz, that still messes up my problem. No matter from what perspective I look at it. I think the phase noise and/or pink noise distort the signal, making it longer, 20Khz+noise (Hz). But if that's not the case... I'm lost.
