Understanding the Role of D1, C1, and Lm in a Boost-Flyback Converter
  • Thread starter Thread starter anhnha
    Converter
In a Boost-Flyback converter, D1 and C1 are crucial for delivering energy stored in the transformer's leakage inductance (Ld) to the output. The role of Lm, representing the non-ideal leakage inductance of the transformer, is to indicate how energy is managed within the circuit as the magnetic field collapses. Leakage inductance can include not only the transformer's properties but also the inductance from the wiring or PCB traces connecting components, which can affect performance if not properly designed. Capturing the stored energy with D1 and C1 enhances efficiency, as dissipative snubbers can generate excessive heat in less optimized designs. Understanding these inductances is essential for improving converter performance and reliability.
anhnha
I am reading about Boost-Flyback converter and this is a bit confusing.
Could you explain the role of D1 and C1 here?
The lecture says that "D1 and C1deliver to the output the energy stored in the transformer leakage inductance Ld." I can't understand what is meant here.
And could you explain why there is Lm there?
Lm is the (non-ideal) leakage inductance of the transformer. You need to understand that first.
http://en.wikipedia.org/wiki/Leakage_inductance
The leakage inductance stores energy the same as Ld does, and that energy needs to go somewhere as the field collapses. It doesn't go through the transformer because that's what Lm is representing, the inductance of the transformer as seen from the primary.
I don't know your source for that circuit so take this as speculation.
I'd wager leakage inductance includes not only transformer leakage as pointed out by mBGuy, but inductance of the loop (of wires or pc traces) connecting transistor S to the power supply and transformer as well.
That inductance can be quite troublesome if the layout is not very good as in the first switcher i ever built.
That's clever, capturing its stored energy with D1-C1 and adding it to output. The dissipative snubbers in my amateur project got quite hot.
this isn't my field of expertise
so just wanting to learn...
mebigguy ... You are saying that Ld and Lm are not physical inductors but are the "product" of the primary of the 1:n transformer ?
At least I think that's what you are saying ?
Dave
I am saying Lm is inside the transformer. I think Ld is a real inductor.
http://www.ijrte.org/attachments/File/v2i6/F0948012614.pdf uses a series inductor for boost.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
