Why does lithiation of arylethers result in a selective ortho product?
  • Thread starter Thread starter Inertia
The discussion centers on the use of butyl lithium as a reagent to deprotonate anisole, forming a lithiated anisole. While it is expected that the lithium would attach at the para position due to the activating methoxy group (OMe), it is suggested that the lithium actually prefers the meta position due to a stabilized transition state involving coordination with the oxygen atom. The purpose of lithiating anisole is questioned, particularly regarding its utility and whether similar reactions can occur without the OMe group or with other electron-withdrawing groups (EWGs) or even plain benzene. The discussion notes that lithiated rings can act as nucleophiles, but it raises the question of their necessity since aromatic rings are inherently nucleophilic. A literature reference is provided, indicating that the reaction may favor the ortho product and does not follow a typical electrophilic aromatic substitution mechanism, with complications arising from the ether moiety influencing product distribution.
Inertia
Is it possible someone can explain the point of doing this, I am having a really hard time grasping the concept. For example if I have anisole and I use butyl litium as a reagent, my understanding is that it will behave like a base and deprotanate the ring, resulting in a lithium bonded to the ring. Since OMe is an activating group it is para/meta directing. One might expect the lithium to therefore go to the para position, but I think I am right in saying it goes to the meta position due to a stabilised transition state where the Li coordinates with the oxygen.
I am not sure what the point of doing this is, what is to be done with the lithiated anisole? Can the reaction be done without OMe, will any EWG do, or indeed could it be done with plain benzene? And what is the point of lithiating? Do we treat a lithiated ring as being analogous to a negative charge stuck on a carbon and it can therefore behave like a nucleophile?
Rings are nucleophilic anyway so what is the point?
Chemistry news on Phys.org
This was an interesting question that I wanted to know about also so I did a quick literature scan. Apparently the RLi reagent is very selective for the ortho product. This reaction may not proceed through a typical electrophilic aromatic substitution type of mechanism. You can read a bit about it here: J. Org. Chem. 1997, 62, 3024-3025. It is a short communication and very accessible, in my opinion. The author makes some statements about potential complication with the ether moiety being responsible for the predominant ortho product. Unfortunately I've about used up my free time, so you're on your own from here.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
