Proving Natural Number e: Exponential Value Explained
  • Thread starter Thread starter henrywang
    Exponential Value
The discussion centers on the limit definition of the natural number e, expressed as (1 + 1/n)^n as n approaches infinity. A common misconception arises when substituting n with infinity, leading to the erroneous conclusion that the expression equals 1. The forum participants clarify that this substitution results in an indeterminate form, specifically 1^∞, which does not yield a definitive value. They emphasize that manipulating limits can lead to different results depending on the order of the limits taken, illustrating that limits do not always commute. Ultimately, the correct evaluation of the limit confirms that (1 + 1/n)^n approaches e, not 1, as n approaches infinity.
henrywang
For proving the natural number, e.
(1+1/n)^n As n approches infinite, (1+1/n)^n ----> e
However, wouldn't it become one as n becomes infinite?
(1+1/n)^n=(1+0)^n=1
Could anyone explain this to me please!
Mathematics news on Phys.org
If you just naively substitute ##n=\infty##, then you would get
(1+0)^\infty = 1^\infty
which is an indeterminate form. Surely, things like ##1^2## and ##1^{100}## equal ##1##. But if the exponent is infinity, then it's an indeterminate form.
Likes 1 person
(1+\frac{1}{n})^n = 1 + n\frac{1}{n} +\frac{ n(n-1)}{2!} \frac{1}{n^2} + ... \frac{1}{n^n}
This does not ->1 as n becomes infinite.
Likes 1 person
(1+1/n)^n=(1+0)^n=1
The manipulation here takes a limit involving one variable and turns it into what amounts to a pair of nested limits involving two variables. The original formula was:
<br /> \displaystyle\lim_{n\rightarrow +\infty} {(1+\frac{1}{n})^n}<br />
The attempted manipulation was to:
<br /> \displaystyle\lim_{{n_1}\rightarrow +\infty} {\displaystyle\lim_{{n_2}\rightarrow +\infty} {(1+\frac{1}{n_2})^{n_1}}}<br />
which is distinct from:
<br /> \displaystyle\lim_{{n_2}\rightarrow +\infty} {\displaystyle\lim_{{n_1}\rightarrow +\infty} {(1+\frac{1}{n_2})^{n_1}}}<br />
Those two nested limits give different results. The first one evaluates to 1. The second one does not exist at all. Limits do not always commute.
One way of seeing this is to imagine the formula {(1+\frac{1}{x})^y} as a function of two variables. It is defined everywhere in the first quadrant of the coordinate plane for x and y. You can imagine extending the definition to infinite x and infinite y by tracing a path going off into the distance and looking at the limit of the function values along that path. It then turns out that the limit you get depends on the path you take.
The prescription in the original formulation was for a path running exactly on the 45° line through the middle of the first quadrant.
Likes 2 people
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
