Finding Dimensions of Vector Subspace Spanning a Set
To determine the dimensions of the vector subspace spanned by the functions e^x and e^2x, it is essential to check their linear independence. This can be done by setting up the equation ae^x + be^2x = 0 and analyzing the coefficients. Differentiating the equation can provide additional insights, allowing for manipulation to isolate one of the terms. The goal is to establish whether a non-trivial solution exists for the constants a and b. Ultimately, confirming independence will lead to identifying the basis and determining the dimension of the subspace.
Pearce_09
The functions e^x and e^2x
I have to find the dimmensions of the vector subspace spanning the set.
I understand how to solve other problems like involving matrices and row reducing, but this function i don't know where to start and how to figure out the dimensions. Any help would be greatly appriciated
thanks
adam
You need to show if it is independent or not to find the basis and consequently the dimension. The first equation is ae^x + be^2x = 0; which you know. To find another, try differentiating the equation and then manipulating these equations to isolate for one of the two terms(ie, e^x or e^2x). Since this is a function, The equation should hold true for all values of t. perhaps try some that will give you an answer for one of the constants a or b.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
