Find vlaues of k so matrix has no solutions, what if u change the position of k?
mr_coffee
Hello everyone! I have a problem, it says Find hte values of k for which the matrix sysem Ax = b has no solutions. I got the answer for this one,
A =
6 2 2
-1 2 3
2 -6 k
b =
I row reduced and ending up gettting:
6 3 0
0 -1 2
0 0 14-k
so k = 14, will give no solutions.
After that he says find:
Image space, nullspace, col space and row space, what are there dimensions, i also did this correctly.
But what happens if he changed the problem and said, Find the values of k for which the matrix system Ax = b has infitinatly many solutions or 1 unquie solution, then what would i do different? Thanks! I'm just trying to get all angles of this problem so i don't mess it up on the exam.
Also what if he puts k in the b vector insteed of the matrix A?
like
b =
-1
k
A =
6 2 2
-1 2 3
2 -6 k
b =
6 3 0
0 -1 2
0 0 14-k
that depends on A, doesn't it. If A is invertible (cols linearly independent) then there is exactly one unique solution of Ax=b. assume A is singular. then if there exists one solution then there are infinitely many, so look if b is in the image.
like
b =
-1
k
depends on the A, same comments apply.
thanks for the responce, To see if A is invertiable, and to find the value of k in which there is exactly 1 unique solution, what would i do to the matrix, is what i was asking, like to find no solutions i row reduced until i got an expression of k, i got k -14 = 0;
so if k = 14, u got no solutions, say he changed the directions and said, find k so that there is 1 uqniue solution, then would it be like
k - 14 = ? that's what i don't get
I told you the answer to that: if the cols are linearly independent then there is a unique solution, and the cols are linearly indepndent exactly when k-14 doesn'te equal zero. you found k-14=0 for a reason, remember. something that is not linearly dependent is linearly independent, it's a binary option. and you know linearly dependent is equivalent to k=14=0...
ohhh my bad, thanks! everything is running together in my mind hah sorrry.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
