Rotational Equilibrium and Dynamics -
The discussion centers on calculating the initial and final rotational kinetic energy of a skater who changes his moment of inertia while spinning. The formula for rotational kinetic energy, KE = 1/2·I·ω², is confirmed as correct. The initial moment of inertia is given as 41 kg·m², and the final moment of inertia is 36 kg·m², with the angular speed remaining at 12.0 rad/s. Participants emphasize using the conservation of angular momentum to find the kinetic energy values. The conversation concludes with clarification on using the provided inertia values for calculations.
raconteur
Rotational Equilibrium and Dynamics - :)
I'm totally stumped!
A skater spins with an angular speed of 12.0 rad/s with his arms outstretched. He lowers his arms, decreasing his moment of inertia from 41 kg·m² to 36 kg·m²
Calculate his initial and final rotational kinetic energy.
Is the formula KE=1/2·I·ω² ?
ω=angular speed.. so ω=12.0 rad/s
so then how would i get I (inertia) ?
and how would i find out initial and final ?
i just need some help
yes
its given. read the question
Use conservation of Angular momentum.
hmm, i think i get it
so.. i use (plug in) 41 kg·m² to get my initial and 36 kg·m² to my my final?
