Galactic Merger: What Will Happen When Andromeda Collides with the Milky Way?
  • Thread starter Thread starter vincentm
Andromeda is on a collision course with the Milky Way, approaching at approximately 250 km/s, and the interaction is expected to result in a merger rather than a mere close pass. The collision will likely take several passes to fully merge, with many astronomers believing it could lead to the formation of an elliptical galaxy. The relative velocities and orientations of the galaxies will significantly influence the merger dynamics, potentially resulting in stronger interactions if their disks rotate in opposite directions. A simulation tool is available to model the collision, although uncertainties in dark halo masses may affect its accuracy. The eventual merging of these galaxies will also connect our Local Group with the larger Virgo Cluster.
vincentm
Hello everyone, :biggrin:
Ok astronomers currently know that Andromeda is going to collide with the Milky Way, i believe i read somewhere that our local group of galaxies is referred to as the "virgo cluster". what i'd like to know is:1) Is the collision between these two spirals going to result in an Elliptical galaxy, or are they going to merely just "brush" by each other like 2 ships in the fog (so to say)
2) At what velocity is Andromeda heading towards the Milky Way, also does the rate of each one's velocty going to have an affect on how they merge ( i think so just want to be sure)?
3)Found this applet http://burro.astr.cwru.edu/JavaLab/GalCrashWeb/main.html
using this and, based on current data is it possible to show how this collision might accour?Thank everyone.
Astronomy news on Phys.org
The local group of galaxies (dominated by Andromeda and the Milky Way) is called, simply, the "Local Group". We are, in turn, a part of a much larger collection of galaxies known as the Coma-Virgo Supercluster. In addition, there is another (more compact) cluster of galaxies known as the "Virgo Cluster" and it's believed that our local group will eventually merge with this cluster.
The galaxies are bound and dissipative forces will eventually force a collision. It will take them several passes to completely merge, however. We don't know for sure whether they will form an elliptical or not, but many believe that the collision of two large spiral galaxies (like the Milky Way and Andromeda) will lead to the formation of an elliptical galaxy. Since we can't watch galaxies collide in real time, it's hard to say for sure.
Andromeda is approaching us at around ~250 km/s. Not only does the speed matter for the resulting collision, but also the relative orientations of the galaxy disks. If the disks are rotating in opposite directions, then the stars nearer to our galaxy will spend more time in close proximity. This leads to a "stronger" collision and more pronounced tidal tails.
I can't load it on this computer, but I can't think of any reason why we couldn't simulate the Milky Way-Andromeda collision...except perhaps for the still large uncertainty in their dark halo masses.
Thank you space tiger.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
