Troubleshooting Multisim Circuit Design: Is My Wiring Messed Up?
  • Thread starter Thread starter Agent
The discussion focuses on troubleshooting a circuit design in Multisim involving AND gates, where the user is trying to achieve a functioning light bulb and timer display. Concerns are raised about potential wiring issues, particularly that the input to the AND gate is connected to the same source, which would result in a constant logic one output. Participants emphasize the importance of correct wiring to achieve the desired functionality. The user is encouraged to review their circuit connections to ensure proper operation. Correct wiring is crucial for the successful implementation of the circuit design.
Agent
Hey, has anyone ever used Multisim? I have to draw diagrams of And gates, etc. The light bulb has to light up and the timer has to display numbers. This is what I got so far: http://img108.imageshack.us/img108/7775/and4ic.jpg
Maybe the wiring are messed up?
what are you trying to do?
the input to your AND gate is from the same source, your output will allways be a logic one..
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
